Author Topic: AirCam-v3.0.7 dont work in D-Link DIR-505 meteobridge **solved**  (Read 2094 times)
Offline jmontamat
AirCam-v3.0.7.build5acf207 works correctly on TP-LINK TL-MR3020, but not in
D-Link DIR-505 FW 1.3, 2.3 MeteoBridge (4697) gives me error and initialization does not work ???
thanks
« Last Edit: September 18, 2014, 04:31:38 PM by docbee »
Offline docbee
  • Moderator
    • smartbedded
Re: AirCam-v3.0.7 dont work in D-Link DIR-505 meteobridge
« Reply #1 on: September 12, 2014, 05:38:53 PM »
Can you please allow me to login as explained here:
http://forum.meteohub.de/viewtopic.php?f=57&t=9885
Please email link to "info(at)meteobridge.com".
Offline jmontamat
« Reply #2 on: September 13, 2014, 05:10:30 AM »
Thanks I will do so
JM.
Offline docbee
  • Moderator
    • smartbedded
« Reply #3 on: September 13, 2014, 11:12:01 AM »
Just fixed with latest update.
Offline jmontamat
« Reply #4 on: September 13, 2014, 12:05:09 PM »
Ok works properly with the latest version
thanks.
JM.
Offline jmontamat
« Reply #5 on: September 14, 2014, 06:05:56 AM »
I'm sorry but DIR-505 does not support aircam AirCam.v1.2.17961.130609.0103, my continued access the same if you want to try
Thank you
Offline docbee
  • Moderator
    • smartbedded
« Reply #6 on: September 14, 2014, 06:35:15 AM »
Can do, but when it works with newest firmware I would like to spare the effort.
Or is there a reason for using the older 1.2 firmware?
Offline jmontamat
« Reply #7 on: September 14, 2014, 06:50:51 AM »
aircam 1.2 has more setting possibilities, contrast brightness etc is more popular and stable, if possible, works very well in TL-MR3020 if it could be possible to work with the two would be perfect.
TL-MR3020 but I plan to use it in a station without AC. power.
Thank you
JM.
« Last Edit: September 14, 2014, 06:55:07 AM by jmontamat »
Offline docbee
  • Moderator
    • smartbedded
« Reply #8 on: September 14, 2014, 09:09:34 AM »
When you do a reboot of Meteobridge after changing the cam, that seems to help.
Reason is that you have it connected directly to the Meteobridge LAN port so that
Meteobridge does some relaying the AirCam into your WLAN. Looks like this needs
a reboot when new cam connected.
I did a reboot and now 1.2 is received fine. Does not seem to be something special with the DIR-505.
But as relay daemon is different between TP-Link and D-Link devices (other OpenWRT
releases used) there might be some different handling... can't say 100% sure.
Offline jmontamat
« Reply #9 on: September 14, 2014, 11:33:34 AM »
Does not work either via the lan bridge the DIR-505, I will use the FW 1.1 works well aircam
thanks for your quick response and interest.
Offline docbee
  • Moderator
    • smartbedded
« Reply #10 on: September 18, 2014, 04:21:13 PM »
Problem is reported by others to be solved with latest update.
Offline jmontamat
« Reply #11 on: September 18, 2014, 04:28:13 PM »
thanks !!
