Author Topic: How to orient WS-1090?  (Read 2418 times)
Offline J-Rod
« on: August 26, 2012, 09:27:58 AM »
Hey guys,
I am a bit confused on how I should orient the weather station. The instructions only further this confusion for me.
Right now, I have the wind vane mounting arm pointing due north, while the wind cups are to the south.  Is this correct?
Offline WeatherHost
Re: How to orient WS-1090?
« Reply #1 on: August 26, 2012, 09:37:29 AM »
There should be a mark on the unit that is to be pointed north.
Offline WATH35
    • Weather Station - Yelm, WA
« Reply #2 on: December 12, 2012, 10:28:30 AM »
And if you put the station together yourself without noting the invisible marking :(
This is a good question.  Which arm should point North the cups or the pointer?
Offline unbidden
« Reply #3 on: December 12, 2012, 10:45:18 AM »
There is a small "N" on the base of the wind vane, the N should be pointed true north. I marked mine with a marking pen to make it more visable for alignment purposes.
Offline WeatherHost
« Reply #4 on: December 12, 2012, 11:02:24 AM »
In my case, the direction arm is pointed west and the cup arm is east.
Offline daqddyo1
« Reply #5 on: December 18, 2012, 10:39:16 PM »
The wind vane and the direction arm refer to the same thing. Look for the north indicator on the housing of this device. Rotate the vane housing to the north.
daqddyo1
The truth is out there.
