Note: trouble with registration? See this for more info.
I have tried the above 3 suggestions by reseating the pc card in another computer and installing a new cable. It still does not work. Do you think the antenna or the pc card is faulty? Thanks.Greg
Assuming the new cable is good, then most likely it's the PC card that's bad. But occasionally antennas do fail.
I had the creeping green slime attack the RJ45 plug and socket at the antenna. Take a real bright light and magnifying glasses/lens and look to see if the little fingers on the antenna socket are OK. There is a LOT of current going up to the antenna, as mentioned enough to make it warm. That along with outdoors moisture or high humidities did a number on the connection with mine. Took some time with pointed toothpicks, cotton swabs and DeOxIt cleaner and tuner cleaner, and got back on line. A small amount of judiciously applied dilectric grease and I've been fine since. Hope it is that simple for you.
