Author Topic: How long does it take for storm to start showing wind.ect ect on your app?  (Read 1373 times)
Offline Fox_Of_The_Wind
  • Hi there!
    • http://www.desotowiwx.com
I just got my storm setup today but I don't have any stats on my page at https://map.bloomsky.com/weather-stations/gqBxp6apnJSnqp2k The light on the storm is flashing green so that must be a good sign?
Does it need some time before it starts showing on the page? or did I set it up wrong?
Anthony
Offline waiukuweather
Re: How long does it take for storm to start showing wind.ect ect on your app?
« Reply #1 on: February 11, 2017, 07:06:40 PM »
weather display does support the Storm now, via the developer API via your bloomsky portal
so that is an easy way to check if the Storm data is at least making it to the API data
(control panel Bloom Sky)
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #2 on: February 11, 2017, 09:56:15 PM »
The site does show your Rain and Wind however currently thought the readings are Zero.  Others that don't have the Storm usually show -NA- or -- in the Rain and Wind fields.
If the anemometer spinning it should start to show the wind speed.  When I had it on the ground it would record only 1.1 but now that its on the tripod it reports much higher speeds.
If it is moving and still getting Zero try spinning it by hand and if still NG try a reset or heaven forbid you may have a problem.  Also try checking it from the app when your doing it.
Once my unit went live online it did start showing readings right away.  It did take a few days but when it rained it recorded it pretty accurately.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
  • Hi there!
« Reply #3 on: February 12, 2017, 05:22:08 PM »
I got it working late last night. Had to reset it. Thanks the the info guys  :grin:
Anthony
