Author Topic: Fan replacement parts?  (Read 1392 times)
Offline azchrisf
« on: September 16, 2017, 01:09:00 AM »
Just got a new 6163. Considering the fan is a wear item, and I would like to keep one or two on hand for when it breaks since it's 24 hr, what is a replacement motor, or entire fan assembly for it?
Thanks guys
Also doing Soil and Leaf 4x
My setup:
https://www.wxforum.net/index.php?topic=41867.0
Re: Fan replacement parts?
« Reply #1 on: September 16, 2017, 02:18:03 AM »
When I got tired of Davis motors frying I used this, most likely better than the stock motor (what's not :roll:), but I didn't use it more than about 4-5 months. Works great but no true idea of how long it'll last.
http://www.jameco.com/z/RF-500TB-18280-R-Nichibo-Taiwan-3-Volt-Dc-Motor-2104-Rpm-1-3-Volt-Range_2158442.html
Offline azchrisf
« Reply #2 on: September 16, 2017, 02:47:28 AM »
Looks good.
I see the fan replacement kit sold by Davis is potted, what about removing the original, and the potting with this replacement?
My setup:
« Reply #3 on: September 16, 2017, 02:58:48 AM »
All I did was dig the old one out, slide the new one in. It needs to be centered into the fan motor housing because it's slightly small. Many ways to make/use something to center the fan which is a must to keep the blades from rubbing the side. Hellofalot cheaper (and probably better) than the whole fan assembly.
Offline azchrisf
« Reply #4 on: September 16, 2017, 03:01:26 AM »
Absoultely. $65 for a fan is stupid.
What do you recommend to center it with?
I can pot it myself with a little liquid rubber like Plasti dip brushed on or something. Not going to hard pot it with epoxy resin or I'll have to buy a whole new fan assembly lol.
My setup:
« Reply #5 on: September 16, 2017, 03:31:21 AM »
All I used is thick two-sided tape (just something I had), wrapped it around once or twice making it a concentric fit and leaving the outside "unpeeled" so it would slide into the hole. Worked beautifully. Like I said, many ways to accomplish the task, but it's gotta be right, very little wiggle room.
Offline azchrisf
« Reply #6 on: September 16, 2017, 08:48:59 PM »
OK Thanks bud!
My setup:
Offline Aardvark
    • turned off
« Reply #7 on: September 16, 2017, 10:28:39 PM »
for me it is easier to buy a new fan from Scientific Instruments,  However, I have found that it is generally the batteries that give up.  I purchase my own rechargeables  and they last about 2 years before quitting.  I have to replace mine fan and Ihave the kit over on the table, probably I might wait until summer of next year to do all that.  Having FARS in winter isn't too great for me.
Offline ct
« Reply #8 on: September 17, 2017, 10:46:05 PM »
My original Davis fans had the motor held in place with hot glue.  The hot glue can be easily removed by putting some isopropyl alcohol on it.
