Author Topic: Weather34 template(non meteobridge versions)  (Read 119406 times)
Offline txweather.org
    • Texas Weather
Re: HOMEWEATHERSTATION Dashboard template
« Reply #25 on: July 19, 2016, 09:27:43 AM »
Cumulus version here http://sandaysoft.com/forum/viewtopic.php?f=14&t=15136
Yes, an instruction page in Word is included.  Any questions or for assistance, I or several other folks will be glad to help in any way possible.
www.komokaweather.com/pws
Edit: click on UVImaps to see one of Paulo's mods.
Paul,
How can we get this mod on the general template for clientraw users? :)
TIA!
« Reply #26 on: July 19, 2016, 09:39:57 AM »
Paulo (forum user meteocaldas) was very kind to share that for Cumulus version.  Not sure if that would be the same for WD version.
Offline weather34
« Reply #27 on: August 10, 2016, 04:23:19 AM »
good morning/afternoon/evening
i have addressed all issues raised and applied where I could or falls into the category where it benefits everyone across all versions . i really would love to add all the personal suggestions you make but some of those are specific to yourselves or your preferred requirement or look etc so please carry on it is your website etc and personal weather station.
WXSIM there is no easy way at the moment unless I create an alternative index.php to include it and it is dependent on user having wxsim but it will come some of you have already done your own
implementations and some are quite impressive.
so here is what i was able to do and some of these have been in the works for a sometime just needed polishing off in terms of visual output.
see the screenshots below , there is a brand new daylight hours script using d3.js i just applied specific css to retain the visual appearance and made some slight code changes to use php values
also now an alternative index.php currently named indexalt.php just rename it to index.php after removing the original or renaming the original(default).
what this does is based on I understand many do not live in an earthquake active fault zone unfortunately i do and have one some 30km from home and its quite active hence my inclusion of earthquake data however to benefit those who dont or have no interest i have added a individual daylight hours script to replace that for those not wanting earthquake data.it is a slimmed version of the moon.php info modal.see screenshots below.
other issues addressed listed below
15th August changes all versions now ver 5
1.updated daylight hours script now shows true minutes better code
2.brand new daylight hours visual display script built with d3.js
3.currentsky.php new scriot now shows offline if data not available or WU is down
4.livedata.php new code for current sky conditions
5.new css added to main.min.css
6.font awesome updated
7. adressed most issues raised
8.curl cronfiles updated
9.weather icons changes to color slight darker yellow #ff9350
10. weather display knots to kmh conversion added
11.fixed earthquake notification time alignment thanks Tina ..
12.New homepage alternative for those not interested in earthquakes you can now display Daylight hours using the the indexalt.php or just delete index.php or raname index.php and rename indexalt.php to index.php
VERY IMPORTANT requires full update now version 5 (20th August 2016)
its been over a year developing just weather..
CUMULUS 5.0
http://www.mediafire.com/download/lb7eia9zeqz5hlc/CUMULUS5LD.zip
CLIENTRAW 5.0
http://www.mediafire.com/download/rhwt4314ka5hhyo/CLIENTRAW5LD.zip
OR brief info @ http://weather34.com/homeweatherstation/index.html   note it doesn't go into how to setup etc its just a reference point without much technical details.
« Last Edit: August 21, 2016, 05:40:40 AM by weatherist34 »
Offline weather34
« Reply #28 on: August 20, 2016, 05:26:05 AM »
hello
all versions were updated August 20th addresses minor issues and fixes . in  version 5 (Aug 20th) version there are new display features in terms of daylight hours and sunrise/set outputs and better formula for moon phase and moon related data. new icons were added all weather icons were redesigned and download includes a PSD in appropriate layers for your own personal editing ..
please note there is no more development for the WS1001 clones template from Version 5 (that is the last one) from myself, this is now in the hands of Ironhorseman(Larry) at https://github.com/lrosenman/WS1001-Template/tree/PostgresDB  who has developed a version for using with PostgressDB.
display mod for WS1001 was stopped at firmware 2.2.5 nothing has been done for many months and was never tested with later versions of firmware .
going forward small updates to the template(s)will be issued in single files from this version on , reduces time to update , in most cases just a simple file replacement and not a full update.
however i would suggest to use the latest version 5 (aug 20th) to benefit for any future fixes,updates etc.
CUMULUS 5.0 (20TH Aug)
cumulus demo dark version http://warehamwx.co.uk
CLIENTRAW 5.0 (20TH Aug)
clientraw demo light version http://www.paulwilman.com/wx.php
clientraw demo using WXSIM dark version http://www.meteosauwerd.nl/pws/
its been over a year now since I began this, I call it an adventure into the unknown world of weather templates but I think its done a full cycle and finally it is where it is today and I am more aware of requirements than a year ago.
« Last Edit: August 20, 2016, 05:28:31 AM by weatherist34 »
« Reply #29 on: August 20, 2016, 04:09:40 PM »
Hi Brian,
I have updated www.komokaweather.com/pws
Yes, that would simplify, and not having to update my customized pages each time.
Offline weather34
« Reply #30 on: August 21, 2016, 05:23:21 AM »
hi Paul i understand i don't enjoy it either but here we go lets put it to test
this daylight module now it will switch to darkness hours output after sunset obviously shows original daylight output from sunrise to sunset
just replace existing if you are on version 5 (Aug 20th)
« Last Edit: August 21, 2016, 06:28:40 AM by weatherist34 »
Offline josecmorales
« Reply #31 on: August 27, 2016, 08:13:23 PM »
Work for meteobridge?
Vantage Pro2 + UV, Airlink, Purpleair, Meteobridge.
Twitter: ClimaGuayana
Blitzortung station: 2934
Weatherlink: ClimaGuayana
« Reply #32 on: August 27, 2016, 10:40:31 PM »
I think it did initially but likely discontinued.
Offline weather34
« Reply #33 on: September 06, 2016, 03:33:18 PM »
something new on the horizon
major major change check the developer version http://weather34.com  and use the menu to see new options , change options on the fly ..
basically all versions , all units , all themes , in one template no more multiple versions , one template for all hardware,all software,all units etc .custom data update periods from 2 seconds to whatever you want to use ,set default theme,set default units etc , uses cookies to remember visitor preferences for 180 days ...
and whole lot of useful options .basically one template for cumulus,meteobridge,ws1001,weather display ...
will release later this week big big massive thanks to Eric Rechlin who spent his whole extended weekend break coding  .
just going to run it now for a few days  to try and catch any problems .
october will see a new GUI setup included to drive the settings.
november will have mysql option and new charts based charts.js
all good things will come to those that wait ... again try it out will be version 7(I think)
Offline SpringHillWeather
  • Weather Hobbyist
  • Spring Hill, Florida
    • Spring Hill
« Reply #34 on: September 06, 2016, 07:22:23 PM »
Very nice Brian!
It makes sense to combine and have customization.
Looking forward to it.
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline weather34
« Reply #35 on: September 07, 2016, 06:21:46 AM »
Very nice Brian!
later today or tomorrow morning  but its looking ok cant find any issues across all data sources be it clientraw,cumulus,meteobridge,ws1001
just need to put a small how to  setup together and then done i think for now..
Offline weather34
« Reply #36 on: September 09, 2016, 12:07:26 PM »
so here we go below is just a cut and paste from http://weather34.com/homeweatherstation/index.html
HOME WEATHER STATION web template is compatiable with Cumulus,Meteobridge ,Weather-Display-Software,Ambient WS1001
and many other weather station software /devices.
The new version ALL-4-ONE released September 2016 has been redesigned now all versions are built into one unique ALL-4-ONE version . ALL-4-ONE offers new menu system to change color theme from dark to light or vice-versa , the menu system now includes facility to change units displayed into various combinations to suit non metric , UK and scandinavian users .
New visual display for rainfall guage using a wave like appearance for rain recorded.New reconstructed css files offering a smaller size and clean code with attention made to appearance i.e. font-smoothing , overall this release offers an even better user/visitor experience because thats the most important aspect "good design is the one that communicates its function and behavior in such a clear and subtle way, that it will excel its purpose not confuse its audience"..Brian Underdown (Aug 2016)
ALL-4-ONE version allow you to make many personal preferences in the settings , this allows you to display your preferred choice of how you want the template to run . Options include choice of theme, choice of wind speed units displayed,setup notification alerts with your preference of what you would like to be notified of, setup data update intervals in seconds from 2 seconds to whatever your weather station updates at . Many other options to fine tune the template to your weather station and location . ALL-4-ONE has new daylight/night hours features including a relative realtime sun position movement .
Offers realtime data streamed from your weather station also includes weather conditions , forecast from Weather Underground (optional *WXSIM forecast data). Earthquake data provides localised regional data and worldwide significant earthquakes via a notification center alongside home page display.
This template was designed to display your weather station data and is compatiable with most browsers which support the -webkit- css . It is possibly compatiable with Internet Explorer or Edge but there is no support or guarantee.
What this template is not , it is not a template designed to scrape data from 100s of external sources it is primarily and was designed to use your own data generated by your weather station or your personal software based data, however generating forecast data is not always possible reliably by your hardware so therefore only 2 external data sources are used by default,Weather Underground & Earthquake-Report.com (*optional WXSIM forecast see http://www.meteosauwerd.nl/pws/).
It is designed with balance of functionality and useage therefore creating a somewhat pleasant user experience across all levels, be it from a curious enthusiast to the hardened enthusiast but remember its all about your weather data realtime nothing else . Original idea was put together using a designers dream piece of software called Sketch  app for MACOSX https://www.sketchapp.com/features/ .
Weather Display software users can get more benefits to use with this template, the developer Brian @WD has included cron job features adapted for the template and additional options for WS1001 users thus expanding the capability of that particular hardware.
Much of what is shown today has come from many enthusiasts ideas and knowledge and continous development ...Have fun its a hobby dont let it become anything else otherwise the fun and enjoyment dissapears..Brian Underdown (Aug 2016)
download via http://weather34.com/homeweatherstation/index.html
feel free to email me with any ideas or problems please note it is now officially EID holiday here for one week so you may not get a reply its time for family gatherings and lots of good food and singing.. have fun and we have Eric Rechlin http://weather.rechlin.net/ to thank for his enormous input and coding , truly remarkable achievement in such a short time..
have fun brian
Offline Jáchym
  • Meteotemplate Developer
    • Meteotemplate
« Reply #37 on: September 09, 2016, 12:21:33 PM »
Hi Brian,
as I posted in the other forum, great job! Its great to see how much progress you have made with this since last year. It is only getting better and better and I hope you enjoy the holiday.
Now, I dont want to look picky, but since you´ve asked for feedback and I know very well that giving just praise is not very useful in terms of moving forward, I just looked at your site and there is one thing that I would maybe change. When I look at the box with the alerts, when I hover over it, the cursor changes to "hand", which usually means I should be able to click it to view something - and other boxes dont do this.
However, clicking it doesnt do anything, so maybe I would just change that to a standard arrow :-)
But please this is of course just total irrelevant small detail, otherwise it looks very good!
 =D> =D> =D>
Offline droiddk
« Reply #38 on: September 09, 2016, 01:19:05 PM »
What this template is not , it is not a template designed to scrape data from 100s of external sources it is primarily and was designed to use your own data generated by your weather station or your personal software based data.
Excellent work, just how I like it!
Regards
Offline weather34
« Reply #39 on: September 09, 2016, 02:39:00 PM »
Hi Brian,
 =D> =D> =D>
Can you point me to an area i cant see anything that appears without a link behind it http://weather34.com
Offline Jáchym
    • Meteotemplate
« Reply #40 on: September 09, 2016, 06:04:38 PM »
If I hover over the alert box (the one in the top row on the very right), the whole box has a hand cursor when hovering over it, but only some text in it actually triggers the popup. But everything in that box has a hand icon.
Now it shows for example
Minor earthquake - Central Turkey on September 9, 2016
And that text has a hand cursor too, although all you can do is select that text with the hand
Offline Jáchym
    • Meteotemplate
« Reply #41 on: September 09, 2016, 06:05:37 PM »
I think Brian it is this class:
.homeweathernotify
it has cursor:pointer set and the whole notify div has this class
Offline weather34
« Reply #42 on: September 10, 2016, 07:30:21 AM »
.homeweathernotify
think i got it i cant see the same here for some reason but i see the cursor:pointer; reference so removed it just wondering if it was there for a reason .
reference how far it has come well this is how it started January 2015( i was sitting in a traffic jam for 4 hours) i didn't actually put to practice until may 2015
« Last Edit: September 10, 2016, 07:32:42 AM by weatherist34 »
Offline weather34
« Reply #43 on: September 10, 2016, 08:43:58 AM »
GOOD DAY
thanks for all the emails overnight was quite surprised but I addressed them all and updated download to reflect everything sent along unfortunately some are personal preferences that I did not add to the general download as they not suit everyone.
1.fixed rain rate rounding now outputs to 2 decimal places i.e 0.21mm or in etc
2.fixed solar/uv trend data data rounding to 2 decimal places i.e 0.11 etc
3.fixed all temp trend data rounding to 2 decimal places i.e 0.25
4.added formula to calculate specifically for clientraw rain rate data output taken from clientraw.txt doesn't affect any other software or hardware.
5.applied changes to notification.php removed cursor:pointer , added better earthquake description data
6.changes to both main.dark.css and main.light.css
7.improved menu to allow users to add more of there own links without menu over-stretching out the screen
8.removed font-awesome from main dashboard all small icons are SVG
9.updated weather icons for better quality on dark theme (particularly the night icons and cloud icons) and better match to light theme
10.added option in settings.php
$rainrate           = '/m'; // set template output for rain rate measurement /m ,/h depends on your software/hardware output minute or hour.
11. fixed in settings.php as per thread on WXFORUM $weatherunderground = 'https://www.wunderground.com/personal-weather-station/dashboard?ID='.$WUID.' ';
however its not in use by default was available in the earlier versions via the menu.si i will leave it in there if anyone still wants to add it back in.
12.updated rain.php to reflect rainrate measurement unit
 if i missed anything feel free to email me again .
download at http://weather34.com/homeweatherstation/
« Last Edit: September 10, 2016, 08:47:00 AM by weatherist34 »
Offline Jáchym
    • Meteotemplate
« Reply #44 on: September 10, 2016, 09:12:47 AM »
.homeweathernotify
That did it :-)
That sketch is nice :) It reminds me of Meteotemplate 0.9 Beta... :D I still have a copy on my HDD :D I might one day upload it from nostalgia for others to look at... I think very few people here actually remember it and used it :D
I recently read an article that was about exactly this topic, it showed some very popular services today and how they began :D For example that funny colorful 3D Google logo and a very simple search box below, or The Facebook back in times when it was (IMHO much better) only a service for messaging your friends and the wall, with no groups, feeds, games :D
  • Weather Hobbyist
    • Spring Hill
« Reply #45 on: September 10, 2016, 12:24:17 PM »
GOOD DAY
Brian,
I downloaded and installed the latest.
Looks good, Thanks!
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
Offline steven west
    • Potts Point Weather
« Reply #46 on: September 15, 2016, 05:11:47 AM »
Hi
Just wondering if anyone else has different Moon Set and Rise times, when compared with other sources?
ALLONE7 (Simplicity)
Moonrise: 15-09-2016 17:06   Moonset: 15-09-2016 05:38
And Saratoga Template has
Moonrise: 16:06 (15/09/2016)
Moonset: 05:15 (16/09/2016)
The moon set is same day I understand  but moon rise is 1 hour difference.
I have checked my TimeZone is correct and UTC offset is 10, in my settings.php file for the template.
TimeandDate.com has MoonSet at 5:20 tomorrow (which is pretty close to Saratoga)
and moonrise today of 16:06 (15/09/2016) which is exactly the same as Saratoga.
Any ideas?
The moon.php version is dated  september 4th 2016
Steven
Potts Point - Sydney - Australia
WS2310 - 1Wire - Windows 10
Offline weather34
« Reply #47 on: September 15, 2016, 09:48:02 AM »
Hi
Any ideas?
Steven
would this be correct ?
Moonrise: 15-09-2016 16:06  Moonset: 15-09-2016 04:38
$TZ                 = 'Australia/Sydney'; // important set your time zone America/New_York for example go here to find your http://php.net/manual/en/timezones.php
$TZconf             = 'Australia/Sydney';  // Your timezone for charts data
$UTC                = '10';  // NUMBER of hours betweeen your location and UTC ,EXAMPLE new york -4 london 0 istanbul 3
$moonadj            = '0';  //adjust this number to correct the moonset time output to your location i.e 1 , 2 , 3 //
$api                = 'xxxxxxx'; // important Weather Underground api key developer key '1234567890'
$api2               = 'xxxxxxx'; // optional Weather Underground api key developer key '1234567890'
$minmag             = 6; // set this to minimum magnitude of eathquake for notifications 5 or 6  or you can set to 12 to switch off if not required //
$rise_zenith        = 90+ 50/60; // try 50/60 or something/60 until it matches correctly to your sunrise .this allows you to fine tune the sunrise
$set_zenith         = 90+ 36/60;  // try 50/60 or something/60 until it matches correctly to your sunset .this allows you to fine tune the sunset
$stationName        = 'SOMEWHERE'; // add your station name or location
$stationlocation    = 'SOMEWHERE '; // add your relative location city,town,village,district, or region
$forecastlocation   = 'SHORT'; // add your forecast location keep it short
$WUID               = 'KZYNEWY'; // YOUR Weather Underground station ID this is used for charts
$id                 = 'KZYNEWY'; // YOUR Weather Underground station ID this is used for forecast
$lat                = '-33.52'; // you can use google maps to determine your lat
$lon                = '151.13'; // you can use google maps to determine your lon
WILL SEND YOU livedata.php update if this correct via pm
Offline steven west
« Reply #48 on: September 15, 2016, 03:00:50 PM »
Hi
I have set my moonadj value to 0 and that now shows valid data.
I wasn't sure what that value should be.
Values now same as www.timeanddate.com
  • Weather Hobbyist
    • Spring Hill
« Reply #49 on: September 15, 2016, 03:53:55 PM »
Hi
Yes mine was also setup incorrectly, changed to '0' and seems to match correctly.
Thanks for the info!
Saratoga
HomeWeatherStation
Meteotemplate
Homebrew
