Note: trouble with registration? See this for more info.
Can meteobridge generate a clientraw.txt file similar to WD?Regards.
Thanks for the reply.Does meteohub generate different types of files at the same time?IE: MBtags.php, MBrealtime, clientraw.txtThanks for the help!
Awesome.Thanks. I will have to figure out where I am going to install it. I might create a freebsd jail.Regards.
Quote from: xcom on May 31, 2014, 03:01:01 PMAwesome.Thanks. I will have to figure out where I am going to install it. I might create a freebsd jail.Regards.Well you should consider a RaspberryPI. Fully supported, see the Meteohub forum.Works like a charm. And at least all parts of the hardware are inexpensive and easy replacable. Use the Raspberry/Meteohub myself now also.Wim
Quote from: xcom on May 31, 2014, 02:45:43 PMThanks for the reply.Does meteohub generate different types of files at the same time?IE: MBtags.php, MBrealtime, clientraw.txtThanks for the help!Yes. You can specify for each file to be uploaded the time. Both the Saratoga- and the Leuven-template need multiple file uploads of the types you mentioned. Fully supported by Meteohub. Meteobridge is also capable of uploading those files, excluding the clientraw files. There is no template file for Meteobridge for those rather complex files.Wim
Hello Wim,Just asking is this meteohub can send clientraw.txt if seting it like 16 seconds or 10 seconds? I already tested weewx with interceptor but its update interval takes long, 60 second max interval is too long to considering changes to the weather units every 10 - 15 seconds. Hope you can confirm this so that I can decide to bought one
