Author Topic: Software to access .WLK files  (Read 4884 times)
Offline griffo42
    • Carina Weather
« on: May 26, 2015, 01:52:03 AM »
Hi
Does anyone know of any software which will allow me to convert the data in my .WLK files into a MySQL database, please.
Keith G
Brisbane, Australia
https://www.kstwx.net/index.php
Davis Vantage Pro2 Model #6152AU
Cumulus latest version
Saratoga Weather World template Cumulus plugin
Carina Weather, Brisbane.
Re: Software to access .WLK files
« Reply #1 on: May 26, 2015, 11:51:46 AM »
Jruys wrote WLK reader sw and he does have a SQL adapter.  You can search the forum for both.
Offline johnd
« Reply #2 on: May 26, 2015, 04:54:48 PM »
I wrote something back in medieval times to create an Access database from wlk files (maybe that's not close enough)? Two big caveats though:
It's literally many years since I last looked at this and in all probability was not a well-tested nor very robust utility. I had intended to develop it further and make it more robust, but the project ran out of time and just became abandoned. For all I know it may not work at all nowadays. But if you get totally stuck with other options...
Second, I uploaded the program to some free webspace from an Internet provider that I used to use around 10 years ago, but the use of that site stopped also many years ago. Yet when I look, the site is still there. How bizarre! I can't imagine that the program is much use now and you're probably wasting your time, but FWIW the program is called WLDS and can be found at:
http://www.prodata.nildram.co.uk/
Cambridge UK
Offline J-W-P
« Reply #3 on: May 26, 2015, 09:04:09 PM »
I was playing around with this a while ago.
What I ended up doing was exporting the .WLK data into .CSV files from  WeatherLink. I exported each year of data into one file.
Then I used a simple python script that I wrote to read the files and insert them into a MySQL table.
“Some are weather-wise, some are otherwise.”   B. Franklin
Davis Vantage Vue --> Raspberry B --> weewx
KOHMASON5  Wunderground
