Randy,
This is "partially true".
The Vue is not compatible with solar UV and leaf wetness, same with the Vue console. The Vue ISS once again is integrated into single unit all-in-one. Totally different ISS from the VP2 ISS and does not support additional sensors.
Now you can use a Vue console for VP2 ISS but it won't see any extra sensors other than the wireless anemometer.
VUE ISS does not support solar/UV, true. The leaf wetness function is in a separate unique station type that has inputs for the leaf sensors, temperature probes and the Watermark soil moisture probes. It is also true that the VUE console doesn't support any readout of leaf moisture (or soil sensors).
However, the "ET" function on the VUE
console does allow for viewing of Solar and UV data from a VP2+ ISS so equipped. Solar or UV can be viewed in the WxCen data area, one at a time. It is kind of a buried function, but it is there. I have viewed my Solar and UV sensors on the VUE consoles.
I thought that this should be clarified.
