You plugged the anemometer straight into the main ISS? Did you set up the console for not seeing the Anemometer Transmitter Kit when you did this? Remember the console is looking for the wireless anemometer transmitter.
Did you test the wireless anemometer transmitter to make sure its not the issue?
Download the manual for the wireless anemometer transmitter. Here is the test mode procedure.
Test Mode
DIP switch #4 on the SIM (see illustration on page 6) is the TEST DIP switch. Switch it to the ON position using a ball-point pen or paper clip. This puts the transmitter in Test Mode. An LED indicator light, located below the jack to the right of the battery on the SIM, will flash each time the transmitter broadcasts a signal, which should be every 2.5 seconds.
If the LED flashes only once and then remains dark, there is a problem with the anemometer transmitter. See “Contacting Davis Instruments” on page 11.
If the LED flashes repeatedly but your console isn’t picking up a signal anywhere in the room, it could be related to one of the following causes:
1.The DIP switches were not correctly set on the transmitter. Review the procedure on page 4.
2.The ID was not correctly set on the console/receiver. Review the procedure on page 5.
3.Reception is being disrupted by RF (radio frequency) interference. Interference has to be very strong to prevent the console from receiving a signal while in the same room as the anemometer transmitter!
4.There is a problem with the console/receiver. See “Contacting Davis Instruments” on page 11.
