I love line #4.
Check your console or Envoy for the version of firmware currently
installed. For Vantage Pro2 Consoles:
1. Check the firmware version or firmware date of your Vantage Pro 2
console by holding down the DONE key and pressing the UP
2. Put your console into Setup Mode by pressing and holding DONE and
the DOWN arrow [-].
Entering Setup Mode saves the current time and ensures that no
EEPROM or FLASH writes are in process when the power is removed.
3. Write down the console’s transmitter ID settings (both the ID codes and
the station types), because you may be required to re-enter them after
updating.
4. Follow the instructions provided with your Vantage Pro2 Updater to
update your console.
What exactly does that mean? Do you remove batteries/power? You would think someone actually checks the instructions they write.
