Weather Software > Meteohub/Meteobridge
Export data from Meteohub to csv
(1/1)
Nisse:
Hi!
Is it possible to export weatherdata from Meteohub to csv?
I can do it from the raw-file, but it is so much data.
If I want to export for instance the solar data, for 24h, with logging every 10:th minute, is it possible?
Or is it possible to write some code for it?
docbee:
There is not function included that can do this. You will need to write some code for it.
May be WSWIN of WD exports of Metehub are closer to what you are looking for.
Nisse:
I tried WSWIN, but I am not sure how to use it.
I choose for instance sol(0) and press Generate monthly data of, and the result be like the picture. I have no measuring data.
Or can someone show me how to write some code for it?
Nisse:
I used the "sol0-min10" and copied the values that I wanted.
Example from "sol0-min10":
20180515144000 795.8 792.0 803.0 0.00
20180515145000 777.6 770.0 787.0 0.00
20180515150000 767.0 762.0 770.0 0.00
20180515151000 759.0 755.0 763.0 0.00
20180515152000 744.7 726.0 758.0 0.00
20180515153000 713.3 702.0 726.0 0.00
20180515154000 702.7 699.0 709.0 0.00
20180515155000 690.5 675.0 699.0 0.00
20180515160000 662.4 646.0 675.0 0.00
20180515161000 633.9 626.0 646.0 0.00
Then I did some csv in excel to get the values.
And it looks like in the picture with 10 min resolution.
