Weather Software > WeatherLink/weatherlink.com by Davis Instruments
WeatherLink 6.03 on Win 10 dies
pcpowernet:
Today my WeatherLink on a USB port has developed a failure syndrome. Load it and a few minutes later Windows pops up with "WeatherLink has stopped".
Run the compatibility search on the shortcut trying all possible iterations, Win 7,8, XP, etc. Reinstalled 6.03, made sure all previous versions are uninstalled. When it is running it does update the data logger and the GUI panel, but get the message that it has stopped.
Win 10 is the latest update (maybe curses) as is my usual practice.
Anyone else experiencing this?
ocala:
No issues here.
ConligWX:
make sure the USB port/Hub you are connected too does not have the Power Management feature enabled. Disable it (untick) and make your PC run in High Performance mode (ie PC does not sleep)
https://www.tenforums.com/tutorials/2843-change-power-plan-settings-windows-10-a.html
pcpowernet:
The root hubs are self powered. Something else is causing W-L to stop.
pcpowernet:
Also, the computer never sleeps. W-L stops within a few minutes after loading.
[#] Next page
