Weather Station Hardware > Weather Station Pictures
My Station Maplins N23DQ/ Ambient WS-1001
Transporterman:
It's a little close to the roof but it seems to be giving sensible readings so far. I'm not that convinced about clamping two hollow tubes together but this is the method and clamp supplied.
I had to fit a stand off bracket and it's still only about a metre from the chimney pot so not ideal. I think it may affect the temp readings in due North winds but we almost never get those and there is also the large building you can see about 100 meters in that direction to mess things up generally anyway.
We are very exposed here to everything from South East to due West so what happens to the weather station during the winter storms remains to be seen!
rods55555:
--- Quote from: Transporterman on August 16, 2017, 06:01:10 AM ---It's a little close to the roof but it seems to be giving sensible readings so far. I'm not that convinced about clamping two hollow tubes together but this is the method and clamp supplied.
--- End quote ---
I also didn't like the idea of two tubes just touching each other, it kind of moves a little bit with only one set of brackets holding everything. So, I didn't follow the manual and made a slight change on the way it's attached to the pole. I used both brackets provided with the unit to hold the short tube that comes with the station, and then I used another similar bracket to hold it on the pole. That way it doesn't move.
Transporterman:
I'm going to keep a close eye on mine to make sure nothing moves, it certainly got a test yesterday as we are on top of a windy hill on the coast. Before I got the stand-off bracket to keep the WS away from the chimney I was going to use a length of capped gas pipe I had, it it was a replica of yours. :-)
Rychu:
--- Quote from: rods55555 on August 16, 2017, 10:49:44 PM ---(...) Incorrectly installed short tube_click
--- End quote ---
@rods55555
The tube supplied with the station should be inserted in the sensor opposite the one on your photo. The hole in the tube should hit the tongue which is in the housing of the station. Then put on a plastic ring and turn it 90 degrees.
This will protect against rotation or fallout of the sensor from the tube. ;)
rods55555:
--- Quote from: Rychu on September 03, 2017, 01:18:58 PM ---
--- End quote ---
@rods55555
--- End quote ---
I did what the manual says, and the notches on the tube are inside the unit, as it should be. And locked in place with the ring.
[#] Next page
