John,
Not sure we are talking about the same thing. The "Dew Zappers" I speak of are a approx 1/4" wide strip of rubber than raps around the outside of the telescope or eyepiece to prevent dew formation on the optics while observing. The width does vary with the application. In the Orion telescopes catalog they are available for eyepieces of 1.25" - 2". Also for finder scopes of 30mm -50mm. And for telescopes of 6" -12".
You are right about the freezing of supercooled droplets which is what led to the doubts I felt concerning these working in my original post. A friend I discussed this with said it would be possible to raise the resistance to increase the amount of heating by the band but did not go in to the method. It does not sound like a good idea to me. In the Orion catalog, the system they show is a 4-channel "Dew Zapper" so that 4 different peices of equipment can be kept free of dew while observing. All of the channels can be controlled independently. the settings are from 0% to 100%. I do not know what actual temperatures these might cause. I have an 8" SCT and the one I have is designed to raise the temperature of the corrector plate above the dew point to prevent the formation of dew, and, it works very well. I used to have to use a hair drier.
Another problem could be that these are usually powered by a 12v field battery. I am electricaly challenged so I will have to involve some body who knows how these may be made to possibly be powered by a solar panel or maybe smaller battery. These would not have to be powered up all the time and I wonder if it would be possible to arrange a system that is easily turned on and off without climbing out on the roof-something I am not willing to attempt
I am going to do some tests as soon as I can get things arranged outside. I will be using an old rain collector. Keep your fingers crossed. Even if it is able to prevent freezing, the other problems mentioned may be insurmountable. But, if some one is electricly gifted, they may be able to develop a similar system that might work. the thought also occurred to me about using the things available to keep pipes from freezing. I believe they are similar to the system used on telescopes. We will have to see.
