Hello, I'm Tom (wtjohnso) and a new member to these forums. I would describe myself as an up-and-coming weather hobbyist. I found the forums through
www.ambientweather.com while investigating a PWS for my home.
I should first state my goals.
1. Wind direction/speed
2. Rainfall collector
3. Temp/Humidity
4. No console or dedicated desktop/laptop (direct update to WU, I'll retrieve my stats from them) (dedicated embedded linux/bsd is ok)
5. Solar powered sensor (most are)
6. Prefer wireless sensor
Resources
1. Ample space to install sensor array/suite
2. Can accommodate wired sensor
3. Backup UPS
4. Existing linux server I can use to log/update WU if needed
5. Budget of $600
So after investigating the possible options, seems that a integrated sensor array/suite that outputs rs-232 would be ideal. I can capture the data using Linux (possibly wview). However that option doesn't seem to fit within my budget. I only found the TWI WRL-25 to output rs-232 and that sensor is fairly expensive. This would also require a wired connection, which is not preferred but acceptable. Are there other lower budget options?
My next thought was, has anyone tried to receive the RF signal from the sensor array without the use of a console? Is this even possible? What sort of signal do the sensors transmit over RF?
Tom
