Did you ever consider opening up and putting a little oil on it.
Beau
I don't think its a lubrication problem. These motors should not sound like they do when they are new and I bet it would void the warranty. Another way to describe the rotaional noise I hear is if you were to take a broom straw and stick it lightly into a conventional fan blade you will hear a ticking sound. Some of the sound is amplified a little because its in a hollow cavity.
I have read a lot of the threads on the accurite site here and on accurite's site and the aspirator problems have been well documented as well as the bearings in anemometer which are sealed bearings. I understand reading that the new double panel units have a hole drilled to allow lubrication of (anemometer ) a sealed catridge bearing if its similar to the single panel units. This type of bearing doesn't lend itself to lubrication. If you do try to lubricate the anemometer shaft you need to apply a drop on the shaft then turn it 180 and apply another drop. The type of lubricant to use depends on the bearing. If the bearing is a sealed bearing it really doesn't lend itself to lubrication. Also the hole thats drilled should be covered so that moisture doesn't enter. I have not seen the new unit, some here have and maybe they could speak to this point. CS told me the motor was the same as in the single panel.
At this point I think I will wait aand see what happens, someone mentioned their fan was noisey fron the start and it lasted for a couple of years .
I would just like to have a year without a problem , it doesn't bother me to spend 40- 100 on a year on a hobby .
Having one unitl go down the first day and troubles with humidity sensor for about six weeks doesn't say alot about quality control
