The Davis recommendation is:
Sensor Troubleshooting
If encountering sensor problems, carefully check all cable connections from the sensor
to the console. Cable connections account for a large portion of the potential problems.
Connections should be firmly seated in the jacks and plugged in straight. Try jiggling
the cable while looking at the display. If a reading appears intermittently on the display
as you jiggle the cable, the connection is faulty.
The voltage is 0-3V, but this might be tricky to measure since you need the excitation voltage applied (yellow wire).
I/O Specifications
Green wire . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Output (0 to +3VDC); 1.67 mV per W/m2
Red & Black wires . . . . . . . . . . . . . . . . . . . . . . . . . . Ground
Yellow wire . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . +3 VDC ±10%; 1mA (typical)
Perhaps you could make some kind of breakout cable to monitor the "green wire" voltage vs. ground. This could be as simple as an extension cable and an in-line coupler where you open the outer jacket of the test wire and strip the green and black wires for monitoring.
Also, you should check your Cat6 connections and junctions from sensor to ISS.
I ran about 100 feet of Cat6 cable to the ISS at ground level.How did you connect the sensor's flat cable to the Cat6 at the sensor end? Is this connection weatherproofed?
Is the Cat6 wire terminated at an RJ11 at the ISS end?
