Author Topic: https://www.airnow.gov/ => https://cfpub.epa.gov/airnow/  (Read 465 times)
Offline gwwilk
  • Southeast Lincoln Weather
« on: May 07, 2018, 11:07:31 AM »
The title says it all.  Any script that links to 'https://www.airnow.gov/' needs the link changed to 'https://cfpub.epa.gov/airnow/' as of May 1.
Regards, Jerry Wilkins
gwwilk@gmail.com
Offline yamiacaveman
    • Penn Lake Weather
Re: https://www.airnow.gov/ => https://cfpub.epa.gov/airnow/
« Reply #1 on: May 07, 2018, 01:37:34 PM »
Hi gwwilk,
Do you know if any of the common scripts used in this forum has to be changed?
Offline wvdkuil
  • Wim van der kuil
« Reply #2 on: May 07, 2018, 01:56:28 PM »
Hi gwwilk,
For Leuven-Template  => http://weather-template.nl/weather28/?p=us_aqhi_page&lang=en&wp=WL#data-area
Inside the air-quality scripts only the  non-essential  "more-information" links need to be changed as the redirect seems not to work anymore.
All other links are still working, all images and the forecast data use the old links, without any redirects.
I will check daily and if other essential links change, I will post an update at the support site a.s.a.p, check https://support.leuven-template.eu/ => menu "Issues"
Wim
« Last Edit: May 07, 2018, 02:02:58 PM by wvdkuil »
