No experience with repeater nor do I recall anyone ever talking about using one for OS...
The THGR968 has been replaced. Not saying these are better, but they are the ones now shipping as replacement "extra" channel sensors
THGR122NX and THGN123N
The THGN123N is the "ultra cold" model.. I have one, not yet deployed, but my radio shack version of thgr968 is in its 4th Cdn winter and never had a problem. The only issue is the below -10c humidty stops reporting issue, but the "ultra cold" has the same limitation. the 123n also does not have a digital readout, which is fine for enclosure deployment, but if you want to do a visual you can not check on the sensor....
You did not put where you live in your profile... but you should probably just go with 122.
Andrew
I'm interested in purchasing a repeater for my WMR968 weather station to add a second THGR968 outdoor temperature sensor that will be placed out in the field. Has anyone used the RT918 repeater? Does it work well? How are they to set up? I've read some mixed reviews but hope to hear from someone actually using one. Would anyone have any better recommendations on a second temp sensor other than the THGR968? Thanks.
