There's a red LED on the wind sensor that flashes when it's sending data, every few seconds. Make sure it's flashing. If not you could have a duff set of batteries, the connections in the battery compartment may need cleaning, or you may have the batteries the wrong way round. The sensors must be reset in a specific order. Try another set of batteries (even the ones from the console for now), double checking alignment, then point the direction sensor at the 'North' marking on the sensor body, then press 'reset', making sure you feel the button click. Then reset the console. By the time you've set the time, date and altitude on the console it should have picked up external temp, humidity and wind data, if the LED is flashing.
