This is Brian's FAQ
http://www.weather-watch.com/smf/index.php/topic,53551.msg430843.html#msg430843
OK.. Maybe I'm missing something with this... If I use Brian's FAQ on uploading this one file, the 'Override' switch disables my regularly scheduled FTP and weather data updates (normally every 5 minutes). On my end, I can do one or the other -- I can create and upload raintoday.gif every minute -OR- I can upload my normal FTP files every 5 minutes. AJAX updates are uploading every 10 seconds.
From what I could gather from Brian's post, the 'Override' switch disables the schedule under 'Control Panel', 'FTP & Connections', 'Web Files Upload Times and Av/Ext' - and instead replaces it with the create/upload values specified in the 'Internet File Creation & Uploads'. (And that is the behavior I am seeing). If I enable the upload of #7 under that screen, checking my 'Status' page at
http://www.indigopc.com/wxstatus.php shows stale WD files. Likewise, if I turn 'Override' OFF - the FTP files upload normally -- but 'raintoday.gif' does not get updated/uploaded.
Does anyone know exactly which files should be set to upload if using the 'Override'? It look as though I will need to customize the create/upload schedule for each one so that the other files get uploaded every 5 minutes.
I'm sorry -- WD does a lot of nice things -- but Brian really needs to clean up the interface and options to consolidate a lot of different things. Thats just my opinion..
Rick
