Author Topic: Port Forwarding Help  (Read 13851 times)
Offline mkutche
    • GosportWx.com
Re: Port Forwarding Help
« Reply #25 on: August 04, 2013, 06:07:50 PM »
ok i give up lol
Mike K.
Gosport, Indiana
Offline cospringswx
    • Colorado Springs Weather
« Reply #26 on: August 04, 2013, 06:25:50 PM »
ok i give up lol
Quitters never WIN!
Ryan
Colorado Springs, CO
www.cospringsweather.com
Davis Vantage Vue
Weather Display Software
Amcrest HD IP Camera
Offline cospringswx
« Reply #28 on: August 04, 2013, 06:48:31 PM »
I can see it here.
You must have his log in info?
Ryan
Davis Vantage Vue
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #31 on: August 04, 2013, 07:44:03 PM »
You are going to have to source on your webpage that http://50.129.82.87:800 address in order for it to be seen.  You need to have the correct URLs for live stream from that address, as well as if you want to serve up single images.
On your particular camera, there are two URLs for live video:
http://50.129.82.87:800/video.cgi
http://50.129.82.87:800/mjpeg.cgi
Not sure what the difference is.
If you want to see that internally on your home network, you need to replace the external wan IP with the internal.  You might also have to pass the user:pass combo as a part of the url (works ok for FF and Chrome, but IE hates it for whatever reason) like "http://user:pass@50.129.82.87:800/video.cgi".
However, you will need to use that external address for it to work on your weather site.
Weather radios:
Reecom R-1650
Sangean CL-100
Uniden Home Patrol I
Offline Dr Obbins
« Reply #32 on: August 04, 2013, 08:26:43 PM »
I just set up port forwarding for my 2 webcams. I won't post the links here because I don't want the cams public.
You internal network address to the cams should be the 192.168.1.108:800 number.
Your external internet address should be the 50.129.82.87:800 number. The 50.129.82.87 is the address to your home router and the :800 is the open port to access the camera.
As BigOkie stated, this is the web log-in to access to you cam.
If you replace the "user" with your user name and the "pass" with your password, it should work. Check that those do not show up in the address bar though or your visitors may be able to access the cameras settings. In the camera's settings there should be another log-in for visitors that you would post.
Offline cospringswx
« Reply #33 on: August 04, 2013, 08:58:28 PM »
He said he gave up. Lol
Ryan
Davis Vantage Vue
Offline Dr Obbins
« Reply #34 on: August 04, 2013, 09:35:04 PM »
so close.  #-o
Offline cospringswx
« Reply #35 on: August 04, 2013, 09:43:51 PM »
Ryan
Davis Vantage Vue
Offline mkutche
    • GosportWx.com
« Reply #36 on: August 07, 2013, 04:15:15 PM »
ok after 3 days of takin a break from this how bout now i used user:user since its for visitors http://www.gosportwx.com/testcam.php
Mike K.
Gosport, Indiana
Offline linuxfreak
  • Hamilton Central Mountain Weather
  • Wink, wink!
« Reply #37 on: August 07, 2013, 06:12:22 PM »
 #-o
And from the page's source:
 #-o ](*,)
George
George
Davis VP2/FARS, VVP, WD, WL, WSWin, Cumulus, NexStorm, StrikeStar, NSLog, XPort(GPS), WASP2, DigitalAtmosphere, ScannerCast(WUradio), Intel Atom N330 dual-core, 2Gig ram, Windows XP Home SP3  #-o
CWOP - DW3112, PWS & WU - IONHAMIL2, AWEKAS - 5112, COWN, WML - WD01901
Offline mkutche
    • GosportWx.com
« Reply #38 on: August 07, 2013, 06:49:19 PM »
#-o
 #-o ](*,)
George
LOL ok i fixed it. hope it works now plz work plz!!! lol
Mike K.
Gosport, Indiana
Offline BigOkie
  • Tulsa, OK
    • KOKTULSA13
« Reply #39 on: August 07, 2013, 09:52:59 PM »
#-o
 #-o ](*,)
George
Looks like it was working fine before it went dark.  :)  I mean the sky got dark.  I still see the overlay.  I think you're good to go now.
Weather radios:
Reecom R-1650
Sangean CL-100
Offline mkutche
    • GosportWx.com
« Reply #40 on: November 13, 2017, 05:06:01 PM »
So... I had to get a new router and the port forwarding is not working.. it's comcast's new gateways the IP im trying to open publicly is 10.0.0.60:8080 see pic below. Note I have tried 8080 instead of 800.
« Last Edit: November 13, 2017, 05:25:03 PM by mkutche »
Mike K.
Gosport, Indiana
