The temp as you see in the image did cross the -40 threshold a couple of times. Again, Davis specs claim -40 but some units may squeeze out a little more range. Thankfully the coldest I have seen since that record day is -36.2 C. Details aside, I would not hesitate to subject the Davis products to extreme cold based on what I have observed over the past 12 years.
Thanks Dean,
Every winter I see cold spells lower than -40F, -45F is commonplace, and every few years there is a cold spell of -55F or lower. The lowest I've known I've encountered was below -60F, the thermometer bottomed out at -60F so I'm not sure how much lower it was.
Anyway, If the Davis pws went to at least -50F I probably wouldn't hesitate to get one. Right now I am still trying to figure something out. They seem to be good and uncomplicated. I did hear back from a Davis sales rep through email, he said their temperature sensors will not read lower than -40. I think that means it won't register -41, since yours obviously registered -40.8C.
Seriously, the way I look at temperature here, anything *above* -40F (-40C) is OK, though I'd prefer temps from -15F to 15F above!
Lonnie at Rainwise emailed and said all their pws read as low as -67F, but the batteries and the electronics cannot be guanenteed below -40. I've asked him about moving the battery and electronics box away from the temp./humidity sensors and using a low wattage battery warmer pad and switching out the battery at intervals during the winter, and perhaps wiring in a larger solar panel, haven't heard back yet of course since it is the weekend.
I not only live in a cold sink valley, but the ridge to the south blocks all available possible sunlight for 2 months each winter. It gets light out, but sun is below the ridge. I don't know enough about solar to know if a wireless pws could run all winter on that little sun. Maybe I should move. Hawaii always looks real good to me about this time of year.
A cabled pws might work better than wireless????? I am electronically deficient so not sure about how I could handle something that complicated.
Gee, it was all so much easier when I worked at the weather stations in the military, all the putting things together stuff was done by someone else!
