Author Topic: Wunderground Update Schedule  (Read 3576 times)
Offline killwilly
« on: July 28, 2009, 02:17:20 AM »
Is it possible to set your own update schedule to Wunderground, other than 'Rapid Fire', if so how?
Alan.
Alan
Offline TorH
    • Været på Fauske
Re: Wunderground Update Schedule
« Reply #1 on: July 28, 2009, 04:37:18 AM »
In VWS as i see you use, also i  ;) I can't find any places to set any update schedule self, just the box for rapid fire. I haven't thought about it before, but lately my data in WU can be five min. or half an hour between, seems like it shall be five min. interval (that's just what i think and read out of my data) . So your question was interresting, anybody??
Davis Vantage PRO2 wireless
VWS V14.00 p103, WD ver.10.37N, WL 5.8.2, VVP.
WeatherFlash
DW1549
WeatherUnderground: INORDLAN14
Location: Fauske, Northern Norway. N 67°15'41", E 15°24'41"
http://bjornli.net
Offline d_l
  • Slide Mtn - Mt Rose
« Reply #2 on: July 28, 2009, 06:45:25 AM »
Yes it is possible.  Meteohubs allow you to set what is called a normal update schedule (non-rapid fire).  This would be at longer intervals than every 5 minutes. I've never tried experimenting with intervals longer than that as I wanted more frequent updates.
Your software would have to have an update interval feature option.
--Dave--
Offline mackbig
« Reply #3 on: July 28, 2009, 07:07:43 AM »
You can pick a schedule just like any other vws feature (ftp, html updates)
Got to the wunderground menu, right under username and password for WU, click "Update Schedule".  I am not at my weather pc, but assume you can pick interval (1,2,5,10,etc, not sure the lowest available) or timer (on the 10's 15's etc)
Page 84 of the 06/19/09 manual for a screen cap.  the section is called "rapid fire" but as long as you dont click the rapid fire check box you will use the standard timer.
http://www.wxforum.net/index.php?topic=4728.0
Andrew
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
« Reply #4 on: July 28, 2009, 08:20:27 AM »
^Yep what I was going to say.  :-)
Offline killwilly
« Reply #5 on: July 28, 2009, 09:02:44 AM »
Andrew,
Not quite sure whether it's me having a senior moment again, but my Wunderground thingy doesn't look exactly the same as the one shown in the VWS manual, similar except that I don't have the update schedule. I only have 'Upload Now' and 'Rapid Fire'.
Most odd!
Alan
Alan
Offline mackbig
« Reply #6 on: July 28, 2009, 10:55:44 AM »
Alan,
If you dont see it, its probably not there.  I see you are using ver 14, since this manual was fully updated in June after quite a while on 14, assumed it was the same.I am on 13, and that screen looks the same to me.
I checked the current wiki and it does not specifically mention a timer, just says if you want real time (every few seconds) enable rapid fire.
Perhaps another ver14 person could have a look.  Or you could pop support at Ambient a note.
Andrew
Offline Gordon
« Reply #7 on: July 28, 2009, 01:06:05 PM »
I believe VWS v.14 uses the frequency of the database timer as the upload schedule to WU.
Gordon
<iframe src='https://www.weatherlink.com/embeddablePage/show/3512bdb6075043fba2e0fbf66996d8f0/signature' width='760' height='200' frameborder='0'></iframe>
Offline TorH
    • Været på Fauske
« Reply #8 on: July 28, 2009, 01:08:39 PM »
I can confirm it is the way killwilly say in the version he use (i use the same). It's rapid fire or upload now there, no schedule.
WeatherFlash
DW1549
http://bjornli.net
Offline mackbig
« Reply #9 on: July 28, 2009, 02:44:28 PM »
Interesting... kind of makes sense.  I guess if you never had it, you would not really miss.  Then again Alan is missing it....
Unless there was a good reason to remove, does not make sense to remove this kind of functionality,   coincidentally I have the option, and my db timer and wu are both set to 20.
Andrew
Offline TorH
    • Været på Fauske
« Reply #10 on: July 28, 2009, 03:21:28 PM »
I now se i WU window in  my VWS v14p87 that it says: " *Note Wunderground update is based on the database timer"  ;)
I didn't notice it in last look  :roll:
WeatherFlash
DW1549
http://bjornli.net
Offline killwilly
« Reply #11 on: July 29, 2009, 01:56:22 AM »
Thanks everyone. I have been experimenting with the database timer in VWS and yes it does alter the upload schedule to Wunderground. You learn something new everyday.
Hold your breath, I shall probably be along with another dumb question very soon.  :roll:
Alan.
Alan
