Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
Gregg, the readings you got show 2 things. 1st, you're definately on the right sensor chip with the way it shot up and back down, 2nd, the gel doesn't have in it the required PEG to work. Like you said, guess I need to try another gel. With the right PEG mixture in the gel the readings will shoot to the top like it did but when it dries the readings should level off at what the moisure level in the surrounding air is by what the PEG is holding. You're closer now.
QuoteOK, I'm going to Lowe's after lunch to get a mailbox post and some quikrete. I'm going to try to do what is shown in this post (more or less):Lowe's sells a two piece metal post with a pointed square end. Just drive it in the ground, no kreet needed. Just did one for my work, cheap too$$$Back to Rapid fire, I have not been able to get the page to load in IE for a couple of months now, but FF is fine? RickI already had a plan in mind, so I went with the post.I've always had trouble with rapid fire in IE (IE7) , but FF does very well.Greg
Quote from: DanS on March 10, 2009, 08:21:08 PMGregg, the readings you got show 2 things. 1st, you're definately on the right sensor chip with the way it shot up and back down, 2nd, the gel doesn't have in it the required PEG to work. Like you said, guess I need to try another gel. With the right PEG mixture in the gel the readings will shoot to the top like it did but when it dries the readings should level off at what the moisure level in the surrounding air is by what the PEG is holding. You're closer now. Yes, at least I know the sensor has a little life left in it. I will look online and see if I can find some good gel. I think we're on the right track. Thanks Dan!
