Author Topic: Davis Vantage Vue  (Read 964 times)
Offline Stevo_vo
Davis Vantage Vue
« on: February 24, 2018, 12:14:42 PM »
im moving in new town in Clifton so im living near the Clifton showgrounds, i have 16.4ft  5 metres pole, i wasn't sure if im able get winds
 if you have any ideas?
Offline waiukuweather
Re: Davis Vantage Vue
« Reply #1 on: February 24, 2018, 03:59:02 PM »
couple of trees that might block the wind a bit from that direction, but looks like not much you can do about that?
« Reply #2 on: February 24, 2018, 04:18:10 PM »
most residential applications will not have the perfect place to install the station
Offline Stevo_vo
« Reply #3 on: February 24, 2018, 04:55:49 PM »
Yeah Clifton have less trees compared bigger towns like Brisbane they dont seem to be 20m or higher trees
Offline Stevo_vo
« Reply #4 on: February 24, 2018, 05:02:33 PM »
i found out the trees about 110ft away from the house
Offline jcookjr82
« Reply #5 on: February 25, 2018, 01:53:29 PM »
The Vantage Vue is a give and take. I have mine mounted up high for wind readings, but I think my temperature readings suffer because of this. Plus, my neighbor has a 2-story home, thus wind readings from the north-west may not be very accurate. All in all, I am satisfied with the unit.
Davis Vantage Vue (Brentwood, CA KCABRENT8 and Arnold, CA KCAARNOL99)
Davis Vantage Pro2 (Lakehead, CA KCALAKEH52)
LaCrosse 2813 (retired 1/17/2018)
