I think we have it.
Here is the issue: The discussion from your particular weather office is using an "&&" *before* the word SYNOPSIS. E.g.:
000
FXUS63 KIND 032028
AFDIND
Area Forecast Discussion
National Weather Service Indianapolis IN
428 PM EDT Fri Nov 3 2017
.UPDATE...
-- Changed Discussion --
The AVIATION Section has been updated below.
-- End Changed Discussion --
.SYNOPSIS...
Issued at 328 PM EDT Fri Nov 3 2017
So when $start and $end are calculated, $end ends up less than $start and when the substr call is made:
$discuss = substr($discussion, $start+0, ($end-1-$start)); // new text (too long to print in cell format)
since $end < $start, it is ignored and you get the whole remainder of the string.
So I modified the code like this:
$sstring = 'SYNOPSIS'; // start of synopis quick text
$estring = '&&'; // first divider
$start = strpos($discussion,$sstring); // starting position of where to keep
$synopsis = substr($discussion, $start); // new - covers case of where && in text before SYNOPSIS
$end = strpos($synopsis,$estring) + $start; // end of where to keep - covers case of where && in text before SYNOPSIS
// $end = strpos($discussion,$estring); // end of where to keep
And using that I'm seeing the synopsis clipped out as it should be.
(Yet another piece of evidence that HTML scraping is error-fraught)..
