Author Topic: Leapin Lizzards  (Read 2214 times)
Offline mikemaps
Leapin Lizzards
« on: November 01, 2017, 04:42:15 PM »
I live in southern Florida & I’m constantly seeing a lizzard (actually it’s an anole, which we have millions of), inside my Vantage Pro 2 radiation shield. Today I was getting erroneous readings on the dew point & humidity, & possibly the temperature. I took the station apart & found a frog in addition to the anole inside. Last time I cleaned the station, I also found a frog & anole. Now the station appears to be reading correctly.
Anyone know anyway to keep these little creatures out?
Offline alanb
Re: Leapin Lizzards
« Reply #1 on: November 01, 2017, 05:00:10 PM »
Could you cover it with a nylon mesh bag ... something like the bags dry onions are sold in?
Alan - Ambient WS-2000, WH31E x5, WH31L, Ecowitt WN32(WH32E)
          Airthings Corentium Home Radon Detector 223
Offline C P RON
Re: Leapin Lizzards
« Reply #2 on: November 01, 2017, 05:30:46 PM »
what about a squirrel type system around the pole to stop the critters from climbing up? :?:
C P RON
Ambient WS-2080 on last legs
9/11 Never Forget
Offline C P RON
Re: Leapin Lizzards
« Reply #3 on: November 01, 2017, 05:34:31 PM »
https://www.amazon.com/Droll-Yankees/b/ref=w_bl_hsx_s_lg_web_3026978011?ie=UTF8&node=3026978011&field-lbr_brands_browse-bin=Droll+Yankees
Droll Yankees SQPM Pole Mount Squirrel Guard
4.7 out of 5 stars   21 customer reviews
Price:   $36.99 Free Shipping for Prime Members
Get $40 off instantly: Pay $0.00 upon approval for the Amazon.com Store Card.
In Stock.
Ships from and sold by Amazon.com. Gift-wrap available.
Color: Black
Squirrel-proofs your feeder or nest box when placed 8' from trees or buildings and 4' off the ground
UV stabilized polycarbonate is highly durable and impact resistant
Proudly made in the U.S.A.
Use it to protect pole mounted feeders and nest boxes
Collet makes dom
« Last Edit: November 01, 2017, 05:36:32 PM by C P RON »
C P RON
9/11 Never Forget
Offline C P RON
Re: Leapin Lizzards
« Reply #4 on: November 01, 2017, 05:45:04 PM »
hhttps://www.amazon.com/Deluxe-Squirrel-Raccoon-Stopper-Coating-Install/dp/B01HMV9DV6/ref=pd_ybh_a_1?_encoding=UTF8&psc=1&refRID=6Z1ZJ4PKQFQHAZ5ABSM7
ttps://www.amazon.com/iPrimio/b/ref=w_bl_hsx_s_lg_web_11023637011?ie=UTF8&node=11023637011&field-lbr_brands_browse-bin=iPrimio
Deluxe Squirrel-Raccoon Stopper 18"-"Extra Slip Coating"- No Tool Install with our Newest Design - Squirrel Baffle. Solid Steel (1 Pack) by iPrimio
4.5 out of 5 stars   400 customer reviews  | 24 answered questions
Price:   $28.95 Free Shipping for Prime Members
this one looks like a better deal
« Last Edit: November 01, 2017, 05:48:23 PM by C P RON »
C P RON
9/11 Never Forget
Re: Leapin Lizzards
« Reply #5 on: November 01, 2017, 06:14:21 PM »
Plenty of them critters up in here in Ocala but can't say I have seen them inside the radiation
 shield.
As mentioned above a screen of some sort would work. Like then screen on a front door.
Just wrap it around the shield keeping it tight so they couldn't slip under it. Secure both ends and also secure the top and bottom.
Re: Leapin Lizzards
« Reply #6 on: November 01, 2017, 06:46:06 PM »
Yup, run a fan 24/7.
Offline Faceng Ret
    • West Melbourne, Florida Weather
Re: Leapin Lizzards
« Reply #7 on: November 01, 2017, 07:05:16 PM »
Running the fan 24/7 doesn't work as the anoles will stick their little heads into the fan. I've removed several until I started putting a 1/4" plastic mesh over the top of the fan. That keeps them out of the chamber.
Re: Leapin Lizzards
« Reply #8 on: November 01, 2017, 07:23:08 PM »
Wow. Another reason for a case fan. If they tried that on mine, they'd never get past the initial "introduction", and decide this ain't the place to be.
Offline mikemaps
Re: Leapin Lizzards
« Reply #9 on: November 02, 2017, 03:10:55 PM »
Maybe, I’ll have to try some kind of mesh, but do you think that might affect the readings? I know I’ve had anoles living in there, probably one at a time and it never affected the readings before, it may have been the frog he was laying right next to the temp- humidity sensor.
Re: Leapin Lizzards
« Reply #10 on: November 02, 2017, 03:42:10 PM »
Can't be any worse than lizard breath. ;)
Offline Faceng Ret
Re: Leapin Lizzards
« Reply #11 on: November 02, 2017, 04:04:01 PM »
My experience with the little green frogs is that they are about 90% water and they are not good at retaining the water. In other words, they pee on everything. If I leave my telescope outside under a cover, I have learned to leave a container of snake repellent under the cover also as the snake repellent also repels frogs. I think the plastic mesh would have a lot less effect than frog pee.
Offline azchrisf
Re: Leapin Lizzards
« Reply #12 on: November 05, 2017, 12:11:16 AM »
Some good ideas. I was thinking of encasing the shield in some fine wire mesh cut to fit around it.
The critters certainly like our stations, I took mine apart for cleaning and found a live bug on one of the plates.
Also doing Soil and Leaf 4x
My setup:
https://www.wxforum.net/index.php?topic=41867.0
Re: Leapin Lizzards
« Reply #13 on: November 05, 2017, 06:58:09 AM »
Something like this with a pull string.
Just pull it over the top, tighten strings and you're done.
Trying to think where I could get something like this locally.
Offline zackdog
    • Winter Park Highlands Web cams
Re: Leapin Lizzards
« Reply #14 on: November 05, 2017, 07:35:21 AM »
If you have a home brew supply store in your area, they should have them.  I use them to contain the hops when brewing, makes for clearer beer. :lol:
"You don't need a weatherman to know which way the wind blows." - Dylan
Vantage Pro2 Plus w/ 24 hr FARS and (2) VantageVues
VP2 uploading via Vue console to CWOP, WU, PWS, and Weathercloud.
Re: Leapin Lizzards
« Reply #15 on: November 05, 2017, 08:20:11 AM »
Thanks Mark.
Good suggestion.
Offline benay ra'am
Re: Leapin Lizzards
« Reply #16 on: November 05, 2017, 08:42:09 AM »
A Pool Vacuum Nylon Mesh/ Bag/Strainer, can source them from Walmart or Lowes...............
« Last Edit: November 05, 2017, 10:03:13 AM by benay ra'am »
CoCoRaHS: NC-JH-80
