Like to help out with hosting costs for WXForum.net? Use the donate page. Thanks!
ADD: On the White, plastic ISS transmitter cover – A80730N729 Humidity calculation - ZDIt was bought from Ambient Weather.I used to do electronics many moons ago. I have some basic kit I occasionally use.
Any console made after January 1 2006 sensors are compatible. The newest SHT31 will require putting the -.9 offset. You can get the stock sht11 or better sht14 without any offset. Scaled has all sensors provided console and transmitter are January 1 2006 and later. The SHT11. https://www.scaledinstruments.com/product/davis-7346-174-pro2-upgraded-digital-temperature-humidity-sensor/
OK - Ordered from Ryan.Cleaning and checking for any other maintenance issues.Thanks.
Will do.WheatonRon: What ratio of bleach solution did you use ?
