Been trying to find detailed information on the optimum mounting location for this sensor. Have not had much luck with finding anything consistent.
How high off the ground should it be?
Which direction should the sensor face? (North, south, etc)
Should it be shaded at all? For example, mounted on the south facing side of a 4x4 post which would create shade from the north?. Or should it be in direct sunlight?
Should it be near trees/vegetation? or out in an open field area?
If mounted on a post, should it be near the top to allow an unobstructed "view" of the sky? or is that not critical?
