Author Topic: WS1001 clone rapid fire  (Read 687 times)
Offline gillesroszak
  • Qui trop écoute la météo, passe sa vie au bistrot.
    • meteokerbach
« on: June 15, 2017, 02:47:26 PM »
Hi guys,
My Aercus weather ranger update is made every 16 s. On the rapid fire weather dashboard Wunderground the update is made every 5 s!!
How can it be possible ?
http://www.dashboard.meteokerbach.fr/template/custom/rapidfire.html
    • Conditions @ CW2274
Re: WS1001 clone rapid fire
« Reply #1 on: June 15, 2017, 03:19:40 PM »
Probably because it's just updating the same thing three times over til your PWS sends a new packet.
Davis Wireless VP2 SHT31 24hr 67CFM FARS
RW Tipper w/ CoCoRaHS
    • meteokerbach
« Reply #2 on: June 15, 2017, 04:11:08 PM »
The interval between two sends can be between 6 and 16 s. I just checked, but I do not know what can determine the gap between two sending
Offline Rychu
  • Type of station: HP1001WiFi & WH2600IP (WS1400IP)
    • Check on-line measurements and forecasts of Gdansk in Poland
« Reply #3 on: August 19, 2017, 01:00:12 PM »
My Aercus weather ranger update is made every 16 s. On the rapid fire weather dashboard Wunderground the update is made every 5 s!!How can it be possible ?
Your station sends packets every 16s, and the window on the "rapid fire" server opens every 5 seconds.
Your data only pops up once to the window - while subsequent openings do not update your data. You can only see the window flick - without changing the data.
    • meteokerbach
« Reply #4 on: August 19, 2017, 01:05:43 PM »
OK thanks for the information Rychu i understand better now
Regards
Offline rods55555
« Reply #5 on: August 25, 2017, 08:57:19 AM »
Here is how often my ws-1001 clone sends information to Weather Underground.
« Last Edit: August 25, 2017, 09:01:19 AM by rods55555 »
Offline dupreezd
« Reply #6 on: August 25, 2017, 10:04:51 AM »
rods55555, the question is what type of data is being sent. Is it just handshakes, retries or actual updates. You will have to look at the actual data packets to see.
WS-1200-IP | ObserverIP | Meteobridge 3.5
WU, PWSWeather - KTXCONRO61
CWOP - FW0717
Blitzortung 2100
Offline rods55555
« Reply #7 on: August 25, 2017, 02:43:11 PM »
Yeah, the router just logs a "generic" information.
