Author Topic: 2080 - Dead or savable?  (Read 1241 times)
Offline RainandSnow
  • Ambient WS-2902D display and array
« on: March 13, 2016, 11:12:01 AM »
My 2080 was working fine and then went blank. I assumed it was the batteries, so replaced the batteries in both the outside sensor and in the inside unit. The picture shows what now shows up on the screen. I have held the up arrow down for 30 seconds with no change? Is the unit dead? Can I do anything else to try and get it back? Thanks.  [ You are not allowed to view attachments ]
It always rains on tents. Rainstorms will travel thousands of miles, against prevailing winds for the opportunity to rain on a tent.”
― Dave Barry
Offline RainandSnow
Re: 2080 - Dead or savable?
« Reply #2 on: March 13, 2016, 11:42:24 AM »
Double check to see if you put the batteries in correctly.
Double checked. They are in correctly.
― Dave Barry
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #3 on: March 13, 2016, 04:32:38 PM »
That looks like a LCD screen edge contacts problem. If you open it up you might be able to press the contacts back in place. Often it's just a taped on ribbon cable or a screwed down pressure connection but by re-securing it in place may do the trick.  If it's still under warranty I'd return it.
« Last Edit: March 13, 2016, 04:35:38 PM by DanS »
Offline RainandSnow
« Reply #4 on: March 13, 2016, 07:51:58 PM »
Okay, so I opened it up and it is a blue ribbon/foam that runs the length of the LCD. It seems to have good contact. Put it back together and got the same results.
It isn't under warranty, I bought it from another person who had it about 6 months before selling it to me.
So, given that where is the cheapest option to buy a replacement? Ambient has it for $49.99 (new). Ebay: $52 (Used) Thoughts?
Thanks.
― Dave Barry
