Author Topic: firmware or console and logger  (Read 1823 times)
Offline chargedbird
« on: September 28, 2008, 01:35:22 PM »
Hello all
I am trying to figure out the version of Firmware on my console and how do I find out the firmware on my data logger?
Brad
Offline tinplate
    • http://www.softwx.com/products.html
Re: firmware or console and logger
« Reply #1 on: September 28, 2008, 05:09:21 PM »
You can get the firmware date by downloading VPLive from http:www.softwx.com (it's freeware) and briefly running it. It will show the firmware date. Or, you could connect to your console via Windows Hyper Terminal (under Accessories/Communication). Hit the enter key to wake up the console, then type in VER (has to be all caps) and hit enter. You will get the firmware data back from the console.
Steve
SoftWx
Offline chargedbird
« Reply #2 on: September 28, 2008, 07:40:08 PM »
Thanks for the reply, I should have been more detailed about my equipment.
I have a USB Wireless Vantage Pro 2.
I went to the web link you sent me, however I dont think that software will work on the USB type, then again I have been known to be wrong many times
Brad
Offline tomcj2
    • CanbyWeather
« Reply #3 on: September 28, 2008, 07:59:25 PM »
From the Davis site:
To determine your current console firmware revision: On all Vantage Pro and Vantage Pro2 models, press and hold "DONE" and press the up arrow (+) at the same time. The revision that is installed will scroll across the bottom of the display screen.
Davis VP2 (6163), WL 5.9.0..  VWS 14.01 p25, Panasonic HM371A camera. WU & W4U KORCANBY3, CoCoRaHS OR-CC-27
Offline Weather Display
« Reply #4 on: September 29, 2008, 12:39:16 AM »
it will work with USB, but you first need to unset the USBexpress mode if the data logger is set to that
using the cprx210.exe (spelling?) program included with the wlik 5.8.1 installation
Brian
info@weather-display.com
