Problems with the forum? Please use Contact or PM saratogaWX with details. Thanks!
2) In order to get the logger to work initially, you must install and configure using WL software.
Quote2) In order to get the logger to work initially, you must install and configure using WL software.thats not true in alot of respects eithere.g weather display can be used to setup the data logger (time, logging ingterval) without having installed weather link at all(if you have a usb data logger you will need to install the silicon labs USB to serial driver (doing it directly means you get the latest version of that driver, which fixes lock up problems with the older driver)
Bottom line:1. Your logger won't get any data until some software program tells it to capture data. 2. After it gets data, it keeps the data until told to erase it by some software program (or until it runs out of room and starts overwriting old data).3. Some software programs can read whatever data is in the logger and tell the logger to capture data. 4. Re-read item 2 above.
QuoteOK. Let's set the record straight. Which programs besides WL can read from a WL logger's memory and which rely only on LOOP commands? I'll start off. The Meteohub server can read some data out of the memory, but I think it is limited to a short gap in the data it missed when its LOOP command couldn't be executed.all the 3rd party PC programs can read the history data to fill their data gap when they are not running(I was not refering to meteohub, which is designed to be running 24/7 on a lower power system)
So why is it that whenever someone has posted that their computer was off with third party software and they missed LOOPed weather data, that no one here explained how to recover the archival data from the logger with the software
