Hello all.
I have a Airmar PB150. I had some issues with it connecting to the PC from the software provided, but resolved that problem you can check out the thread in "Other weather software" if you like.
The PB150 is connected to a FURUNO Combiner then to my PC. On the Combiner there is a indicator light that blinks fast indicating a good signale from the Airmar weather station. Anyways, after I got the software issue fixed it was working good. I was attemting a firmware update when I got a error. I rebooted and tried to connct to the sytem agian and now it seems like somthing is wrong. That indicator light is now a SOLID light. When I go to connect it through the COM port the ligth will blink but only when its trying to connect then stays solid. Now the system is not working at all. As the manual says remove power sourse and wiat then power it back up it should reboot. No luck. Iøve tried to use HyperTerm and rest the unit to factory defult setting and still nothing.
Is there any other suggestions to help?
