Author Topic: MyAcuRite is current but WU offline for 3 days now  (Read 2451 times)
Offline hdtvluvr
« on: June 28, 2017, 10:44:16 PM »
When I visit WU, it says:
This PWS is not reporting
Last updated: 6/25/2017, 7:13:46 PM,
3 days ago
In MyAcuRite, I stopped sharing and deleted the station.  I them reenabled sharing and added my sensor.  Still not uploading to WU.
What am I doing wrong?
Offline DoctorKnow
Re: MyAcuRite is current but WU offline for 3 days now
« Reply #1 on: June 29, 2017, 07:51:21 AM »
3 days ago
Wrong password to Wunder? Use the key, and be sure you are not confusing an l with a 1 etc. I did this before and it wouldn't work.
Offline Garagedude
« Reply #2 on: June 29, 2017, 10:18:35 AM »
I'm having the same issue with WU. When I changed from Pc-Connect to Smart Hub it quit uploading to WU. I created a new WU station with no luck, I've checked PW with no luck. Could they have blocked me?  Is there a catch for getting the smart hub to work with WU? I've not had any issues with My Acurite just WU
Garagedude
Offline worachj
  • Twin Cities, Minnesota
« Reply #3 on: June 29, 2017, 10:37:34 AM »
If it helps, here is a screen shot of my current MyAcuRite.com setup.
AcuRite Atlas
KMNSAINT173
Offline hdtvluvr
« Reply #4 on: June 29, 2017, 07:23:32 PM »
OK, here is what I have done in MyAcurite
1. Deleted sharing
2. Deleted my station under Sharing to Weather Underground
3. Edited Sharing and selected "Share"
4. Added my station using KTNMUNFO2 as the station name
5. Entered Password using the Station Key found under "My Profile - My Weather Stations" on the WU website
6. Entered my SmartHub name
7. Selected my sensor (I only have 1 which is a 5 in 1)
8. Saved settings
WU still says:
3 days ago
but 6/25 was actually 4 days ago.
Not sure what else to do.  Here is my screenshot.
« Last Edit: June 29, 2017, 07:25:35 PM by hdtvluvr »
Offline worachj
« Reply #5 on: June 29, 2017, 08:04:01 PM »
Sounds like you've done everything right, it should work. Who knows, there could be problems with AcuRite or WU servers. These links may shed some insight on what to try. Good Luck!
Why isn't my data appearing on the forecast page for my location?
http://help.wunderground.com/knowledgebase/articles/128980-why-isn-t-my-data-appearing-on-the-forecast-page-f
Why is my station indicating Station Error?
http://help.wunderground.com/knowledgebase/articles/128979-why-is-my-station-indicating-station-error
« Last Edit: June 29, 2017, 08:07:37 PM by worachj »
AcuRite Atlas
KMNSAINT173
Offline Garagedude
« Reply #6 on: June 29, 2017, 08:18:10 PM »
I'm done and checked and have all that the same way. I'm to the point I don't care anymore. I've emailed them with no reply being sent back. What other site can I post to ?  I will not spend any money to do it either..
Thanks for all your help.
Offline hdtvluvr
« Reply #7 on: June 29, 2017, 08:23:17 PM »
According to WU, High was 149.6.  Assuming this was on the same day as it stopped reporting (6/25), I looked back and the graphs in MyAcurite for the 25th and the high was 94.
Maybe station is flagged due to their QC check?  Wondering how WU got 149.6 degrees??
Not sure what to do now.  I have also sent an email to "Contact Support" at WU.
« Last Edit: June 29, 2017, 08:25:12 PM by hdtvluvr »
Offline DoctorKnow
« Reply #8 on: June 29, 2017, 10:07:33 PM »
Use another software besides myacurite. Try Vis Reader, or Weather Display.
Offline hdtvluvr
« Reply #9 on: June 29, 2017, 11:05:40 PM »
I found the Mac version of Weather Display.  Not sure how old it is since it isn't on the front download page.  Downloading now.
I can't find any instructions on using it with my web bridge.   Or any instructions really.   Any help?
I'm not opposed to leaving MyAcurite if that is my issue with sharing to the web.
Offline Garagedude
« Reply #10 on: June 29, 2017, 11:12:56 PM »
If us Acurite users use Vis Reader, or Weather Display, will there be a way to see our station on our phone like we do with "my acurite" ?
Offline worachj
« Reply #11 on: July 02, 2017, 12:03:24 AM »
1. Deleted sharing
8. Saved settings
WU still says:
3 days ago
I noticed your station started reporting today shortly after 3 PM.  Did you make any changes or did it just start working again by itself?
https://www.wunderground.com/personal-weather-station/dashboard?ID=KTNMUNFO2
AcuRite Atlas
KMNSAINT173
Offline Garagedude
« Reply #12 on: July 02, 2017, 01:42:41 AM »
Well,
Mine is back for now ??
Offline Garagedude
« Reply #13 on: July 02, 2017, 01:53:46 AM »
I just checked on WU. I have two stations reporting..but I only have one station and one smart hub??
Offline DanS
  • Chiang Mai weather
    • ThaiWx
« Reply #14 on: July 02, 2017, 03:48:15 AM »
You mentioned previous (reply #2) "I created a new WU station with no luck, ". Maybe that's your second PWS reporting?
Offline hdtvluvr
« Reply #15 on: July 02, 2017, 12:05:30 PM »
I had a backup 5 in 1 waiting for when a sensor stopped working.  The rain gauge stopped working 2 or 3 weeks ago so I was going to replace the unit when I had time.  Since MyAcurite was still working and I am waiting on reviews of the new Elite, I decided to swap out the 5 in 1.  After swapping out, and resetting MyAcurite by deleting the old 5 in 1 (Named 5in1 sensor 2) and adding the new 5 in 1 (Named 5in1 sensor) it appeared back on WU.  But at first the temp was off by reading 100.  Probably because I had the belly facing the sun while it was on the ground and the unit heated up.
Everything is good so far.
