Author Topic: New firmware for Red and Blue  (Read 3825 times)
Offline ConligWX
  • #conligwx
    • conligwx.org
Re: New firmware for Red and Blue
« Reply #1 on: January 08, 2018, 06:32:51 AM »
Thanks for the update! =D>
Regards Simon
Offline dupreezd
« Reply #2 on: January 08, 2018, 06:43:24 AM »
Thanks, but nice storm going on in the gulf and I am in the right spot to get into the action, being just north of Houston.  :-). Will update when it is over.
« Last Edit: January 08, 2018, 06:46:31 AM by dupreezd »
Davis VP2 6163 | WiFi Logger
CWOP - FW0717
Blitzortung 2100
« Reply #3 on: January 14, 2018, 02:24:01 PM »
I just updated both the RED and BLUE units. What means the target/bolt animation? Is it just something mesmerizing and cool  8-) to watch, or does it signify anything?
Offline W0BTU
« Reply #4 on: January 14, 2018, 03:10:33 PM »
No, it doesn't mean anything. Clicking on it disables the animation, according to the post there.
Mike
Stations: 1977, 2294
Offline DaleReid
    • Weather at Eau Claire, WI
« Reply #5 on: January 14, 2018, 05:41:01 PM »
My updates went slick, as usual.
I'm not sure about the throbbing lightning bolt.  Maybe it was a sort of 'I'm alive' indicator, but there are plenty of other things that one can watch to know the controller is working and your connection to it's web page generator is still OK.
Nice to turn it off, but I'm happy with the utilitarian view, impeccable function without glitz.  On the other hand if it indicated a packet sent or a strike detected, that might be worth the trouble and CPU cycles to make it function.
In any event, it is nice to see releases again.
I hope that he will eventually get the header in RED for RED systems and Blue for BLUE systems, since many of us have both running and I have to squint to see the little station numbers in the upper right corner.
ECWx.info
ECWx.info/t/index.php
Offline dupreezd
« Reply #6 on: January 16, 2018, 08:40:03 AM »
Dale, have you power cycled your system after installing the new version?
The reason I ask is, I replaced my power supply after installing the new update. I then noticed my Amp stayed Red and had that sinking feeling, Ohh dang, blew something up. Did a UI reboot and it went to green. Swapped back to the old PS and the same thing happened. UI reboot and Amp was ok again.
Anyone else seen this?
Edit: I did not see this with version 8.3
« Last Edit: January 16, 2018, 08:45:07 AM by dupreezd »
CWOP - FW0717
Blitzortung 2100
Offline DaleReid
« Reply #7 on: January 16, 2018, 09:00:15 AM »
No, I haven't recycled the power.  The systems have been powered up for almost a year without cycling power.
I can try it I guess.  But I don't want to miss the big storm just south of me!  A few thousand miles south, that is.
I'll give it a whirl later today.
ECWx.info
Offline dupreezd
« Reply #8 on: January 16, 2018, 09:07:17 AM »
Ok, no problem.
Is this your station- Eau Claire, WI USA
CWOP - FW0717
Blitzortung 2100
Offline DaleReid
« Reply #9 on: January 16, 2018, 09:16:34 AM »
yes, 1505 and 976 if I rrecall corrrectly.
ECWx.info
Offline dupreezd
« Reply #10 on: January 18, 2018, 01:40:42 PM »
Dale, no need to do the test. I found this post today.
https://forum.blitzortung.org/showthread.php?tid=2458
and appears to be the problem I  ran into.
CWOP - FW0717
Blitzortung 2100
Offline ConligWX
  • #conligwx
    • conligwx.org
« Reply #11 on: January 18, 2018, 07:45:56 PM »
8.4 is just out a couple of days ago..
8.4 (2018-01-17)
* new: mouseover for satellites
* fix: try to initialize amplifier more often after reboot (RED)
http://tracker.blitzortung.org/firmware/
Regards Simon
