Author Topic: New website not responding  (Read 707 times)
Offline madriver71
    • Blackhawk Weather
« on: June 18, 2018, 07:15:42 PM »
I've uploaded all the template files from Saratoga Weather to my Go Daddy accound including the WD plugin files. Weather Display is up an running, but nothing is showing on the website. Obviously, there is something I haven't enabled.
Any help would be greatly appreciated. Thank you.
Dick - KA1TE, Galena, OH, USA
Re: New website not responding
« Reply #1 on: June 18, 2018, 09:16:03 PM »
An URL to your weather website would greatly assist in further diagnostics.  The symptoms described above are insufficient for diagnosis :(
Offline madriver71
    • Blackhawk Weather
« Reply #2 on: June 18, 2018, 09:21:55 PM »
My apologies...blackhawkwx.com
« Reply #3 on: June 18, 2018, 09:29:15 PM »
It's working at http://blackhawkwx.com/wxindex.php
You'll need to delete the home.html/index.html file and rename wxindex.php to index.php to have it appear just using http://blackhawkwx.com/
In the install instructions it has the last bit to implement the site 'live' as
When you've decided that the new site is to be made 'live', then use these steps to have it become the primary display.
   1. Rename (on your local disk) wxindex.php to index.php
   2. Edit flyout-menu.xml for flyout-menu to replace wxindex.php with index.php in the link.
   3. Upload flyout-menu.xml and index.php to your website.
Hope this helps, and enjoy your template website :)
Offline madriver71
    • Blackhawk Weather
« Reply #4 on: June 18, 2018, 09:34:40 PM »
Thank you very much. I can't believe it's working.
Offline madriver71
    • Blackhawk Weather
« Reply #5 on: June 18, 2018, 09:42:16 PM »
Any idea on why the data is not updating ? It states the last update was 2011.
« Reply #6 on: June 18, 2018, 09:46:49 PM »
The basic website is working.. but... the little 'testtags.php not uploading ' note on the home page just indicates it is using sample data (from my system in 2011) to display the weather conditions.
Do follow the setup for Weather-Display at https://saratoga-weather.org/wxtemplates/setup-WD.php to get the tags file (testtags.php) and the realtime file (clientraw.txt) to begin routine uploads.. then the site will reflect your station's weather conditions.  You can check for 'freshness' of the data at http://blackhawkwx.com/wxstatus.php
Also, don't forget to unzip saratoga-icons2.zip and upload the /forecast directory completely (and all subdirectories) to get your forecasts fully working.
Offline madriver71
    • Blackhawk Weather
« Reply #7 on: June 18, 2018, 09:48:41 PM »
Will do, thanks
