Author Topic: Where to find local CAPE values?  (Read 4802 times)
Offline SLOweather
    • Weatherelement Moline IL
« on: September 08, 2015, 03:06:11 PM »
I've found a color coded map, but I'd really like to find the actual CAPE value for a location.
Any pointers? I've been doing some searching...
Re: Where to find local CAPE values?
« Reply #1 on: September 08, 2015, 03:45:45 PM »
The only place I get actual CAPE values is in the "Forecast Discussion" portion of my NWS office, if it's discussed at all. When it is, the sounding is usually presented in unmodified and modified values, dependent on the lifting method. Other than the map you stated (which only works with little or no clouds), that's all I know.
« Reply #2 on: September 08, 2015, 03:48:18 PM »
BTW, SPC will advertise CAPE values also, but only if there's something worth reporting.
Offline ValentineWeather
« Reply #3 on: September 08, 2015, 04:01:38 PM »
Yep SPC may mention in Mesoscale discussions. There is a new experimental map out also if you click on surface based cape. http://www.spc.noaa.gov/exper/mesoanalysis/new/#
Randy
« Reply #4 on: September 08, 2015, 04:07:47 PM »
Very cool Randy, thanks!
« Reply #5 on: September 08, 2015, 04:18:14 PM »
Turn on cape under thermodynamics. Will give a current still of sector your in. Has auto refresh on it too.  8-) Very cool, I just found this myself.
 http://www.spc.noaa.gov/exper/mesoanalysis/new/viewsector.php?sector=20&parm=pmsl&underlay=1&source=1#
Randy
« Reply #6 on: September 08, 2015, 04:58:53 PM »
Yes, lots to play with!
Offline SLOweather
« Reply #7 on: September 09, 2015, 09:36:16 AM »
Thanks!
