All I can suggest is something like this: It takes time to calibrate VWS vs your actual station location and geography... compared to what 'you think you should be seeing"...
Under "advanced Parameter settings"... mine is set for "Max Windspeed in Database Update Period".... this has proven 'most reliable' for my siting over time... now, you must be careful 'reporting' manually to local NWS office, etc, and await a database update from console, etc... otherwise you are likely to under-report your max gust. Rarely will the 'graph' actually support your 'max'. Now... the calibration and operation of VWS, and I assume others, DOES NOT resolve itself overnight... this takes time, patience, and attention.. eventually you will have a 'pretty much' calibrated data source. Like most of my posts, this will be open to challenge, so expect differing opinions. My experience is you cannot "plug 'n' play' this stuff.. you must 'be a scientist'.. so to speak...
I note that my 'latest' graph at the moment (2:43am ETS) might appear similar to your reported graph.. I'm too lazy to do screenshot.. but you might also note that this is confirmed and validated by MESO, and other reporting sites. It's also confirmed, over time, by various 'hand helds'; and nearby stations,...
My point is that VWS will allow you to "modify" readings, over time, to become 'most representativie'... for example, my settings for 'wind speed', 'humidity', etc... over time.. have been 'calibrated' to match location and other varibles. This DID NOT happen overnight..
So, patience, observation, common sense, etc... you'll have a good station... BUT.. if you DON't report to MESO, CWOP, etc, you have, in my opinion, little chance of, over time, becoming 'valid'... if you understand what I'm saying... Failure to ask questions as you have asked, is also a 'dumb' move... keep asking.... !
There are a lot of folks who think you should be able to "start' a Vue or VP2, or whatever, and automatically be 'perfect'... sorry.. this isn't the real world... why so many posts on "calibrating rain gauge?" or "VUE vs COCORAHS".. and all that crap...
One other thing.... DO NOT REVERT TO PANIC MODE if WU has something retarded on your site... many of us have ceased sending to WU, because it's become notoriously unpredictable. Build your OWN site, let your LOCAL NWS know you're online,.,. WU is NOT what it used to be.!
