Nothing there, but Com1 and Com2!
You know, I never got the window with options to select the "USB Drivers", that was described in the original installation how-to (Rev A 2/1/07). I was following the instructions to move the WL folder to another drive, wiped the computer, moved it back onto the new 'puter at C:, then installed 5.9.2. I did get an error saying it could not find a particular .msi file in the temp folder, so I just tried to run the program and it started. It makes sense that it would, because I installed it before I wiped the whole deal. I was trying to save my data.
Bottom line: the install did not go slick and sweet.
So, if there's an easy way to use the install (which I'm not thrilled about because in the folder are duplicates of many things...some from 5.9.0 and some from 5.9.2), but if there's away to get the cp210 driver in there now, we can do that.
Alternatively, I'm not opposed to going back to the CD (5.9.0), starting from scratch there, then updating to 5.9.2. Fun!
