Author Topic: serial to usb adapter  (Read 10018 times)
Offline aleutianman
« on: November 05, 2009, 03:33:25 PM »
tried to use a keyscan 19 hs to work with my lc 3610 installed the cd loaded the latest driver from key and it doesnt recognize the connection had a moschip serial but for some reason i am not getting anything there either. ive deleted everything from the puter and reloaded it all and am now frustrated. the comp has xp for the os.
Offline d_l
  • Slide Mtn - Mt Rose
Re: serial to usb adapter
« Reply #1 on: November 05, 2009, 04:19:03 PM »
Are there any other USB to serial drivers loaded on the computer, say an old one that you aren't using.  I think there is a potential for conflict if there are multiple drives from different manufacturers.
--Dave--
Offline Weather Display
« Reply #2 on: November 05, 2009, 05:34:52 PM »
the 3600 station type does not use standard serial communications
and so only a good quality adaptor and driver will work
try seeing if there is a more recent driver available for your adpator
Brian
info@weather-display.com
blackjack52
  • Guest
« Reply #3 on: November 05, 2009, 07:09:44 PM »
I recently switch from my express card-serial to usb-serial.
http://www.wxforum.net/index.php?topic=5694.msg52134#msg52134
Offline aleutianman
« Reply #4 on: November 06, 2009, 12:25:53 AM »
tried everything and gave up. returned item to store.
Offline aleutianman
« Reply #5 on: November 06, 2009, 12:29:07 AM »
ordere an iog guc232a online which most everyone here agrees is the way to go
Thank You everyone
Offline aleutianman
« Reply #6 on: November 11, 2009, 12:33:05 AM »
back to square one. i now have the iog. loaded the cd and still am not getting my lacrosse to recognize it. i loaded the xp driver 2.0 and then tried the hookup from the guc232a to the serial on the ws. nada :? ](*,) :mad: now what? give up.
Offline wuhu_software
    • WUHU Software Yahoo Group
« Reply #7 on: November 12, 2009, 06:12:20 AM »
Get the latest IOGear driver from their website.
Offline aleutianman
« Reply #8 on: November 12, 2009, 03:26:04 PM »
have the latest driver now how do i install or make it work?
« Reply #9 on: November 12, 2009, 08:34:57 PM »
After the install, you usually need to reboot.
After the reboot, the computer should use the latest software and you should be good to go.
Offline aleutianman
« Reply #10 on: November 14, 2009, 07:55:42 PM »
wuhu i did that and i can't get the lacrosse to connect it doesnt see or recognize anything at any of the coms. we are limited here in alaska as far as getting the right equipment.(fairbanks) will i have to try to go back to a serial device?
« Reply #11 on: November 15, 2009, 08:34:16 AM »
Are you sure that you are attempting to connect to the correct port? Have you checked the device driver status under Hardware Manager to see if the driver is functioning? You might want to verify the port number assigned to the adapter by right clicking the port in device manager, select properties, then click the Port Settings tab, then the "Advanced" button. If you are trying to run the USB adapter through a USB hub, I would not recommend doing so, connect it directly to one of the USB ports on the machine.
Offline aleutianman
« Reply #12 on: November 16, 2009, 12:21:36 PM »
assertion failed see the Visual C + + documentaion on asserts. this is junk to me i am now a comp person so i don't know what to do anymore?
« Reply #13 on: November 16, 2009, 04:57:52 PM »
What did you run right before the assertion was displayed??
Offline aleutianman
« Reply #14 on: November 17, 2009, 01:46:40 AM »
heavy weather
« Reply #15 on: November 17, 2009, 06:03:43 AM »
heavy weather
I would re-install it. If I had to guess, it is trying to open the wrong port.
You could also run WUHU instead of Heavyweather, Heavyweather is a bit of a resource hog. I am assuming you are using a WS-23XX station type?
http://tech.groups.yahoo.com/group/wuhu_software_group/
Offline aleutianman
« Reply #16 on: November 17, 2009, 02:28:39 PM »
ws 3610-al. i have deleted uninstaled reinstellled double checked my com ports?
« Reply #17 on: November 17, 2009, 04:51:00 PM »
Still crashing on startup?
For the WS-36XX You must be running Heavyweather Pro, not Heavyweather or Heavyweather Beta 2.0. Pro is also not to be confused with yet another version, Heavyweather Professional.
http://www.heavyweather.info/
WUHU can also talk directly to the WS-36XX units.
Offline aleutianman
« Reply #18 on: November 18, 2009, 04:51:22 PM »
wuhu software tried running hvy 2.0 beta as you can see by the pictures i don't know what else to do ](*,) [-o<
« Reply #19 on: November 18, 2009, 08:56:28 PM »
Firstly, For a WS-36XX, you do not run Heavyweather. The screen shot you are showing is for the WS-23XX station types only, not the WS-36XX.
Kill Heavyweather, do not run any version of it (Pro, Professional, or any other version).
In WUHU General Settings, in the first Box, select WS-36XX Direct Serial, to the right of that, select the com port that the console is connected to. Hit Start.
Offline aleutianman
« Reply #20 on: November 19, 2009, 02:55:03 PM »
did as told heres where i am at
« Reply #21 on: November 19, 2009, 04:56:44 PM »
Are you 100% certain that you have the console connected properly to COM5?
Cables secured?
Offline aleutianman
« Reply #22 on: November 21, 2009, 12:46:49 PM »
synched the clocks, rechecked the wires, ready to throw the towel in
« Reply #23 on: November 21, 2009, 01:26:57 PM »
I hear you there.
Can you try connecting to a different computer?
    • Watts Bar Weather
« Reply #24 on: November 21, 2009, 03:16:45 PM »
Looking at the picture of the log made me think of what I've been going through the past couple of days.  It may or may not be applicable.
I have the 2315.  It worked fine for months, then it just stopped (-- for outside temp and wind).  I moved it into the next room so that it would be just a couple of feet from the outside transmitter (it's running wireless).  Did a complete reset of the console.  The sensors started receiving and I thought everything was well again.
However it would not talk to the computer.  I started getting "corrupt information" and "cannot match the clock" and "cannot read storm alert" error messages in the log.
I rebooted, changed from serial to usb, reset the console, tried the console on ac only, battery only, tried unplugging and replugging the data cable, etc.  I took the batteries out and unplugged the console and let it set for 24 hours.  nothing seemed to work.
It wasn't WUHU, because Cumulus wouldn't read the console, either.
This is strange, but the way I got it working was when I did another reset of the console, when I got to setting the barometer alarm (I guess that's what it is), I changed some of those setpoints (I hadn't done that in the past) and low and behold, it started working.  I have no idea why.
Anyways, I don't know if the 36XX unit have that feature in the setup, but it might be worth a try.
There's my $0.02
Good luck!
