re: How do you find your battery power indicator
There is probably a better way but the way I did it was to work my way through my local home network IP network addresses in my browser. I have my router set to begin assigning addresses at 100, e.g.,
http://192.168.1.100. Then I just changed 100 to 101, 102... until I found my IP-100 living at address
http://192.168.1.105/.
Look at the bottom of the list on the Current Weather tab to see the battery voltage from your station.
If you get crazy and want to access the Admin page the user ID / pw is admin / admin.
Okay, I found the better way (as long as you have a rainwise.net page that is working. Log in to that and click on settings from the menu bar. Then click on My IP-100. It shows your local IP in parentheses.
