Weather Station Hardware => The WxTech Dream Machine => Topic started by: wxtech on November 23, 2011, 02:36:36 AM
I selected the Acu-Rite VN1 as the sensors for the first version of the dream machine. I think this will be the easiest/quickest way of getting a wireless system operating. I'm working on getting data from the Acu-Rite VN1 (aka 5-in-1) Integrated Multi-Sensors. The $99 kit bought from Walmart has the 5-in-1 Integrated Multi-Sensors and a 01010 Display.
I opened the display and found the receiver circuit board. I attached a cable to the receiver outputs and found the data stream and a 'PON' signal as you can see in the attached image. The image shows only the leading portion of the data.
When PON goes high, the data stream has a signal burst then the preamble code followed by the data. To get data into a host PC, all that is needed is the Acu-Rite 01010/5-in-1 sensors and a $30 Arduino microcomputer. The Arduino connects to the host PC via USB.
I have the data stream decoded, just have to write the Arduino sketch to provide the data to the PC.
