Author Topic: additional wmr200 base unit? or can i use a WMR698??  (Read 3546 times)
Offline zl4plm
« on: August 27, 2009, 09:49:29 PM »
Hi all
I have a WMR 200 system running here in Christchurch NZ that I want to add to my home weather service online
Id like to remote mount the base unit next to the Pc in my home office but still need a display for the lounge etc
Is it possible to add a second wmr200 base unit on its or some additional readout??
I thought about a cheaper WMR698 for the lounge
not sure if the wmr200 sensors would work though
any ideas?
thanks
Simon
Offline sam2004gp
  • Mount Crawford, Virginia
  • Weeeeeeeee!!!!
    • Mount Crawford Weather, VA
Re: additional wmr200 base unit? or can i use a WMR698??
« Reply #1 on: August 28, 2009, 08:42:25 AM »
The WMR-968 console will not work with your WMR200.  They use different sensor protocols on transmit of their data.
If you can purchase an additional wmr200 console, then I don't see why it should not work.
After all basically the console is a radio receiver.
On my WMR968 based station, I have 2 OS-wmr968 consoles, and 2 other Radio Shack consoles, that use the same sensor protocol.  So in total 4 "radio receivers" for my sensors.  All Works Great.
Offline mackbig
« Reply #2 on: August 28, 2009, 08:56:49 AM »
If you just want a display console for the lounge, you could pick up a wmr100 console, as its the same protocol as the 200 and much cheaper.
Only $91.95
http://www.ambientweather.com/orwmr100ca.html
Then you can leave your existing 200 connected to the computer in the "office"
A 200 console runs $171.95
http://www.ambientweather.com/orwmr200ca.html
The 200 looks nicer, but if its just the basics you would like to see in the lounge the 100 should be fine.
Might be able to find some used 100 stuff for cheaper on ebay.. might even get a whole 100 station for about that price or less. Used sensors are not usually a good idea, but the console is just a reciever, and you can alway keep the extra's for spare parts.
Andrew
edit: spelling, and forgotten link, etc
« Last Edit: August 28, 2009, 09:21:33 AM by mackbig »
Offline sam2004gp
  • Weeeeeeeee!!!!
« Reply #3 on: August 28, 2009, 09:03:16 AM »
Mackbig, thanks about the wmr100 idea.  I had totally forgotten about that one.
Offline mackbig
« Reply #4 on: August 28, 2009, 09:23:15 AM »
Its easily forgotten.   :lol:  I would not reco to anyone as a station, or pc interface, but for a simple reciever for occasional viewing, should probably be ok.
Anderw
Offline killwilly
« Reply #5 on: August 29, 2009, 02:12:29 AM »
I use exactly the setup that Andrew (mackbig) suggested and it works fine.  :grin:
My 200 is in my study next to the computer and the 100 is in the kitchen.
Alan.
Alan
Offline zl4plm
« Reply #6 on: September 15, 2009, 06:23:33 PM »
thanks guys
I will have to find someone who exports them ambientweather will not send outside the US and canada
an extra WMR 100/200 it will be then!
thanks
Simon
Only $91.95
Andrew
