Author Topic: Weather Oracle Temperature Error  (Read 2284 times)
Offline litavecz
« on: September 09, 2012, 12:20:39 AM »
Hi.I have the original Weather Oracle display and I have a problem with the temperature readings.They're way off.Like around 160-170 degrees.I also have the multi-display in another room that is working fine.So its not  an issue with the sending unit.I swapped receivers between them and it's not that either.So I figure its an issue with the display itself.I was wondering if any one knew where to start trouble shooting the temperature display itself.I do have a little electronics experience.Just enough to be dangerous.Any suggestions?Thanks
Offline William Grimsley
    • Newton Poppleford Weather
Re: Weather Oracle Temperature Error
« Reply #1 on: September 09, 2012, 02:06:36 AM »
Hi there,
160 degrees! Woooh! That will be a software error or the connevtion between your station and oracle.
Try reinstalling.
Will
http://www.newton-poppleford-weather.co.uk
Davis Vantage Vue - Cumulus v1.9.4 (1084)
Weather Underground: IDEVONEX12
Met Office WOW: 717144
PWS Weather: ENG128597
Offline mfd38
    • Millis, MA Current Conditions and Forecasts
« Reply #2 on: September 10, 2012, 05:25:36 PM »
Try resetting the display as described in the manual...
http://www.weatherconnection.com/manuals/WO%20DISPL.pdf
