So here is my take on the original question. I have been using a dfars for a year now and when I upgraded to that from a passive setup, my accuracy increased significantly. I have my ISS station mounted over my lawn in an area the gets fairly good sun all day. The key here is where you locate the ISS. Even with the original passive setup, when the temps got up to the 90 degree range , my readings where only bumping up around 3-4 degrees. With the dfars in the same location, only 1-2 degrees. When it snowed both setups looked the same at nights and the dfars improved the low temp reading during the days when there was sufficient sun to supply the panel with energy. I just upgraded my dfars to the 24hour fars setup. I have 2 days of very hot weather and we now are going to cool off for awhile. What I have noticed now is the temp and humidity readings are even more stabile and now my temp reading has no more than .75 degree increase when compared to my precision mercury gauge setting next to ISS located out of direct sunlight. When I say .75 degrees, that might be a little high. I suspect over time I should easily be able to see a +/- .5 error. So getting back to original question about the 24hour fars setup worth the price upgrade, in my opinion it is living up to what I expected. More stable and accurate readings. Got all the parts from SI and that was a good experience. Ryan offered his opinion on a 24 hour fars upgrade path and that was information that helped to make my path forward for my upgrade. I decided to spend the money and upgrade to the Davis design. Thanks Ryan for your help and quick service.
