Three weeks after mounting my TX‐56U‐IT I stopped getting readings, with the last reading at 2:30pm on a sunny day. Days later I climbed up to the roof and attempted to reset it. The act of getting to it caused the mounting pole to move and water started coming out of the weep holes. I then took it down and encountered more water coming out of it. Opening up in accordance with other posts (I didn't lose anything
), I found that the inside was really wet with water sloshing around in it (to the extent that water was between the solar array and the glass, and on both the top and bottom of the circuit board). I then proceeded to dry everything. I noticed corrosion from one side of the battery leads. Each of the batteries were registering <1.0Vdc under load. So I now know why I lost communication with the unit.
The solar array puts out ~2.75 volts with the batteries removed. After 4 hours under a 60 Watt incandescent lamp, the solar array has only charged the batteries from 1.99V to 2.10V.
Is the solar array putting out the correct voltage? Does it sound like I will need to replace the batteries? Should I just call La Crosse and have them replace the unit under warranty, or have I voided the warranty by taking it apart (I will be able to put it completely back together.)?
I could not find the source of the leak though. Has anyone encountered this type of problem where it appears that rain has leaked into the Wind Sensor? If so, where is it most likely leaking? and how can I seal up the leak?
Or am I just blessed with a defective wind sensor that should be replaced under warranty?
Thanks in advance for your help.
