Hi Andy,
Looks like a good build. One question. Have you checked the memory and the hard drives to make sure they are compatible? Doing so will save a bunch of head banging.
Memory Listing - Look for 1600MHz
MemoryDevice Listing
Device ListingJust for the record, I haven't seen a hardware/device listing since Microsoft introduced the WHQL listing for Windows 98SE, NT3.51/4.0 /2000
Good luck with the build. Just take your time, and don't get in a hurry. And if you need any help, please yell.
Edit: When you do get it built, check your CPU Temps closely. You may want to get a larger CPU cooler than the stock heatsink/fan. I have started using a Corsair H60 Cooler. It is self contained, so you don't have to add water. It comes completely assembled with the hoses and radiator/fan attached. It IS a challenge to mount to the CPU, while making sure you don't drop the radiator/fan onto the motherboard.
